If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Got the engine out and started disassembly. Making a little progress. Didn't get to drive a Stude today. Just sat in it with T.O. Pictures of that later.
wow, a southern stude with a heater? I just finished installing my blower motor, and now after 40 years my car has interior heat again...yahoo. Tex, I thought the sat. night special got a rebuild this spring, what up with pulling the engine now, did something let go? Junior
Yes Junior a heater. I have heard a lot of people say they don't work good. This is not the case with mine. It works great, and so does the defroster. No, I didn't do the rebuild yet. The tornado damage to our home, garage and property has taken a lot longer to get repaired and cleaned up than I thought. So, just starting on the build. Sure do miss driving. I wanted to go to the S.E. zone meet in Jacksonville, and my oil pressure wasn't where I wanted. After pulling the pan I found a worn crank. Since I want to drive anywhere and not be worried, then a crank was in order. This led to a rebuild.
