Parting 62 Hawk
  • Parting 62 Hawk
    A few months ago I posted about a 62 GT Hawk that I was parting out. I sold the doors and some trim at that time. I got real busy at work and kind of stopped for awhile.... Things have slowed down again, and I have started dismantling it again. This car has been sitting for 40 years, and honestly there isn't much here that is any good. If you are looking for anything, send me a PM and I will let you know if what I have will do you any good.
    Some items
    Hood, bent corners
    Trunk, dented
    Rear fenders, rusted in front bottom
    Front fenders, spoken for
    Front and back glass, front has wiper scratch rear looks good
    Hydrovac, core?
    Heater core, antifreeze ran out! Probably OK
    Defroster core and fan
    Dash, pretty crappy, but complete, all gauges switches and wires
    Complete power steering unit
    Headliner stainless. Pretty nice!
    Headliner bows
    Rear quarter windows
    Complete chasis. Looks pretty good going to clean it up to make sure it has no rust out
    Can bring parts to South Bend. I will be there Wenesday and Thursday.
    1962 Champ
    51 Commander 4 door
    Kurt,
    Do you have a good used driver side front grille housing? Also, need a pair of good or better used parking light lenses that go inside the lower grille housings? Thanks
      The drivers side grill is OK, BUT, the housing for the parking light is rusted out. The passenger lens is OK, the other side is cracked.
      1962 Champ
      51 Commander 4 door
        That frame; assuming its easily fixable, is worth a few dollars to someone wanting something stronger under a 1953-61 C/K body.
          first looks of the frame look to be promising. It appears to be quite solid.
          1962 Champ
          51 Commander 4 door
            Hello Kurt, I have 60 Hawk, looking for a radiator and the steel L-shaped bracket htat holds the fog light assembly...
              Sorry, I don't have either.
              1962 Champ
              51 Commander 4 door
                Hi Kurt:
                How about interior door sill plates (under door and on top of the carpets?) Also, need lower Torque Converter cover for 55 V8 President Automatic Tranny.
                Mine is 55 C Body President.
                  Lower torque converter I can help you with. Sold the sill plates. PM me with what you need exactly.
                  1962 Champ
                  51 Commander 4 door
                    hello Kurt
                    i am looking for the upper steering cloumn shaft - this is the part onto which the turn signal is attached. it must be complete with inside components and wiring. cost ? i am coming to south bend from south africa for teh meet.
                    i have a 61 right hand drive hawk - i want to add power steering - i know that it would not just bolt on and modifications are necessary - please advise if possible what parts would work and what i must modify. _ advise on cost of entire system including bolts and brackets, hoses and pulley.
                    regards
                    krish
                      Hello Kurt I have someone looking for headliner chrome for his 62 may need bows too. How much?
                      Thanks Anne
                      Mabel 1949 Champion
                      Hawk 1957 Silverhawk
                      Gus 1958 Transtar
                      The Prez 1955 President State
                      Blu 1957 Golden Hawk
                      Fresno,Ca
                        One more thing...... As I look closer, I can see that the rear seat footwells are in really good shape. I would cut them out if anyone is interested. The front frame mounts are good too. The ones that are attached to the firewall inside the engine compartment..... I see that CE reproduces both of those, so if anyone likes, I can salvage that before I haul the rest of this rusty hulk to the recyclers. I plan to load up the "rusty junk" this weekend.
                        1962 Champ
                        51 Commander 4 door
                          Kurt any side trim/moldings?
                            The stainless trim is still pretty good. All other emblems and trim are pitted and not much count really. Like I said earlier this car has sat for 40 years. Its first 10 of use was in the rust belt. Not very kind to any kind of metal. The stainless that is left that is what I would consider to be very good is the strip that covers the fender bolts at the rear. The door trim went with the doors. I am letting the front fender trim go with them. The short piece under the quarter windows was ruined when I removed them. My bad.......... The wheell well mouldings are gone. I still have the headliner bows, although I have been asked about them..... The stainless in the window trim is still available and looks like it would clean up real nice.
                            One more thing. If any of you have parts and such for a 51 commander 4dr, or a Champ pick up, I might entertain swapping parts......
                            1962 Champ
                            51 Commander 4 door
                              Kurt,
                              What condition is the batwing crossmember in? It bolts under the frame and supports the door pillar posts? About 6 feet long.
                              Allen
