Wheels
  • Wheels
    Anyone have any idea what a good price to pay for a set (5) of Ford Crown Vic wheels , which have the same bolt pattern as our Studes ?
    Most "Pull" or "Pic" your Part Yards get $5 or $10 each, also Tire Dealers have lots of "take offs" cheap.
      Already pulled from the donor----$10 each.
      Jim Barker
      '70' Avanti II
        Good price, but good luck keeping full wheel disks on the Ford rim. My Avanti MOPAR rims hold the disks fine, but the Mercury ones on my '53 will throw them within a block from home at 25mph speeds. There seems to be a slight taper on the rim that my Stude disks don't want to get a hold of... even welded tits on the rims... no help.
          what year is the mopar rims witch model that wil work with disk breakes. i know i need 15 inch rims and a 5 hole bolt patern, i wont to go 225 75 15 ,plus i need a speed rate tire for 125 mph is it the zed ( Z) rated tire i need, will the tires rub when put them on a 1963 avanti. thank you very much, ray i also wont to stay whith stoke hub caps cheers
          rawise
            My Friend gave me Crown Vic wheels and they fit a 53. Good Luck with the post ! I Had a friend post some of mine and WOW ! ED
              I had that same, exact problem after mounting a set of mid 50s Stude wheels on the GT. The hubcaps would not stay on for much over a mile or two, but it only happened on the front. I never figured out why. I switched to 6" Ford wheels and have not lost a hubcap since. I have ran several sets of Ford wheels, and never experienced that. Have not ran Mopar wheels yet.
                Ray ....if you want me to pick up these rims let me know .
                  hi Bob are you over to A&W tonight in town if sow i will see you ther ray thanks
                  rawise
                    Yes we plan to go ...see you there
