The rod frequently falls off at the front ball socket. The spring clip that goes around the rod is shot. Does anyone know where I can get a new clip?
57 GH Throttle Pressure rod spring clip needed
My first car on the road again!
The old girl has never been sold to the public
Grandpa was a Studie dealer. He got it off the car carrier in 1956 and drove it until 1959
My dad: 1959-70
Me: 1970-2015 and counting!Tags: None
I may be wrong...but isn't there a groment and a clip.. Stude International has the groment that would make the rod tight. I might be thinking of the actual shift groment or the kick down groment. Usually anything clipped has help to keep it tight. I have a 61 so we are close but not exact.
Originally posted by jg61hawk View PostI may be wrong...but isn't there a groment and a clip.. Stude International has the groment that would make the rod tight. I might be thinking of the actual shift groment or the kick down groment. Usually anything clipped has help to keep it tight. I have a 61 so we are close but not exact.My first car on the road again!
My dad: 1959-70
Carb Linkage Swivel Fits 1/4"-28 RH thottle linkage rod <LI sizcache="0" sizset="19">1/4"-28 RH Male x 1/4"-28 Female
View this item
$4.49
Ships
Today
This is from JEGGS.
555-15741
Carb Linkage Swivel Fits 1/4"-28 LH thottle linkage rod <LI sizcache="0" sizset="24">1/4"-28 LH Male x 1/4"-28 Female
View this item
$5.99
Ships
Today
555-15740
View this item
$4.49
Ships
Today
This is from JEGGS.
555-15741
View this item
$5.99
Ships
TodayMy first car on the road again!
My dad: 1959-70
I was looking around for you and so far that is all I found. I did find several suggestions though and two good ones were:
Use small wire ties around the elongated clip. OR
Take a small hose clamp cut a slot in it for the rod and tighten that around the bad clip.
OK I'll leave you alone unless I find the exact clip.
Originally posted by jg61hawk View PostI was looking around for you and so far that is all I found. I did find several suggestions though and two good ones were:
OK I'll leave you alone unless I find the exact clip.My first car on the road again!
My dad: 1959-70
