59 to 64 Bell housing
  • 59 to 64 Bell housing
    Anyone within a reasonable distance of southeast Michigan. Mine has the 2 upper tabs broken off and don't want to repair it.
    Thamks in advance,
    Kim
    hudsonbaker@myexcel.com
    Someone will need to know if your "Bell" Housing is a Clutch Housing or a Torque Converter Housing in order to help you.
    All of the Flight-O-Matic and Power Shift converter Housings are the same '56 to '64.
      It would also be good to know if the bell housing is for a six or a V-8.
      60V-L6 - 60 Lark convertible
        Sorry I didn't provide enough info. Bellhousing for 58 to 64 V8 standard shift,except 61.
        Kim
          Kim, why not the 61? unless it is a 4 speed then they are the same, how many do you want? sure are heavy to ship.
          Candbstudebakers
          Castro Valley,
          California
            If the one you have is at all repairable, I would consider making the repair. That way, you eliminate having to dial-in another housing. Of course, if it's not repairable, you have no choice.
            --Scott
              They should all be dialed in, you never know if every thing is original or not after over 50 years of being screwed with by how many others.
              Candbstudebakers
              Castro Valley,
              California
