On the way home from a show with the R2 clone Thursday night this happened.
Clutchless
OUCH! That's gonna leave a mark! Did the clutch just "explode"? Hope no other damage was done.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Must have been a Corvette or something quickly disappearing behind you
My Dad once had all but one of the rivets bust out of a clutch on his 53 coupe. Bumped the pedal until it centered itself and then drove it the 70 miles to my grandparents house where it was fixed...
Been there, done that.
When SI or other suppliers rebuild these clutches, do they replace JUST the fiber material or do they also replace the sheet metal mounting tabs that are riveted onto the center disc?
If you look at thier catalog, they sell just the fiber material, but not the black spring steel mount tabs. I worry that if those are not replaced, at least every so often, those will worry and break.
On my old race bug motors we would twist off the fiber and those tabs alot. We had to start going to the 3 puck ceramic disc because the center steel was alot thicker under the pucks.
Side question, related though, Sadly my truck has the 9.25" clutch, does anyone have a crossover part number or a high performance disc and PP cross reference I could find?
That was a NOS disc. If your truck has the truck bell housing, Studebaker had an 11 inch . Also there is enough room to use a diafram pressure plate. I'm using the 11 in diafram out of a 4.3 s 10 in mine. If you use the gm clutch disc, the center of the flywheel needs to be made larger as the hub has a larger diameter. Jim
Kelly, with a bit of digging, I could probably scare up the proper truck V8 bellhousing, flywheel, and transmission. Unlike the crank, they wouldn't be freebies. The chancier part would be finding the proper engine mounts and shift rods to complete the deal.
Edit: Quite likely I have a new clutch disc and PP as well.Last edited by Roscomacaw; 05-19-2012, 10:19 AM.No deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
I am sure that the 11" disc would be much better, but everything is dialed in with what I have. The bell housing is dialed in to the block. The clutch works smoothly and perfectly. The shift rods are perfectly adjusted. I hate the thought of having to change all of that for a bit bigger clutch. Unfortunately I have the small car bell housing and can not just swap flywheel, and disc and PP. It would require all of the list I just sited to be redone.
Then my motor mounts are all set. They are a bit far forward from what they should be if they had used the correct trans cross member and everything else.
I am just not sure I am ready to pull out all of the stuff that works so well. Then of course if I toast any more clutches, that is a pain to swap mout and expensive as well....how do you spell canundrum?
edit: Just realized going to the truck bell housing and bigger clutch may also affect my drive shaft length, radiator hoses, throttle linkage, power brake booster vacum line, and goodness know how much more stuff. And thanks for thinking of me Bob. Any chance you have a NOS 9.25" disc and PP for sale?
