289!?!?
  • #16
    found it guys thanks, P7I703
    What do the #'s tell you specifically about the 289?
    • #17
      The only thing it tells you is that it is a 289 from a 1960-model car, probably a Hawk, but conceivably from a police marshal or some other special order vehicle. As such, it could have been equipped several different ways, and if it has an oil filter, it is the partial-flow type that is mounted on top of the engine.
      Skip Lackie
      • #18
        It is probably the original 289 engine in your 1960 Hawk. The build sheet will tell you for sure.
        • #19
          thanks again guys, got another one....
          if you install a point-less distributor do you still need the ignition coil?
          not sure how these two work together.
          • #20
            Yes you do
            1964 GT Hawk
            PSMCDR 2014
            PSMCDR 2013
            Victoria, Canada
            • #21
              The points (or pointless sensor) make and break the circuit through the primary of the coil. The coil provides the high voltage secondary for the spark plugs.
              • #22
                Thanks a million
                • #23
                  Nice ride!
