289!?!?
  • 289!?!?
    Hello all, wonder if anyone can help me out,
    how do you know if you have a 289 or the smaller V8??
    1960 Hawk
    thanks in advance
    Look at the front of the block , to the right of the oil filler tube.
    There is a machined flat area with a STAMPED number.
    289's start with a P , and 259's with a V .
    Bill H
    Daytona Beach
    SDC member since 1970
    Owner of The Skeeter Hawk .
      On the drivers side front of the engine on top there is a machined flat spot. That is where your engine serial no is. If the number starts with a V it is a 259 and if it starts with a P then it is a 289 if JT then "R" series. This is on 60's and newer engines maybe older but definetly not the flat heads or 6 cyl.
      Mark
        Here's what a stamped number looks like.
        This stamping begins with a V, so this engine is a 259:
        If yours begins with a P, as has been stated, and falls within the range of
        P70501 through P74701
        OR
        PC2201 through PC2501
        it is probably your 1960 Hawk's original 289 engine.
        The "C" in both the sample picture and the numbers above denotes an engine built in South Bend for Hamilton ON Canada production. BP
          thanks guys I will check it out,
          new Stude owner will need lots of help!
            thanks for the pic
              And, as most of Us know, the 1955 President 259 V8's engine number also started with the letter 'P'
                I did not know that, Thanks SN-60
                Mark
                  That's because they are yet to receive the June 2012 Turning Wheels Co-Operator, Ed. <GGG> BP
                    http://www.studebakerdriversclub.com/V8EngineID.asp
                    Skip Lackie
                      Ok Stude ladies and gents, I did a quick look and this is what I found,
                      no letter in front of these sets of numbers, please advise...
                        Those are not serial numbers but either part numbers or casting numbers.....your looking in the wrong spot. Look for a number that is stamped in not raised.
                          go to this page and scroll to the bottom to look at the picture referencing where to look for your engine number, you are not looking in the right spot.
                          it is on the front right block when looking at the engine standing in front of your car. You will likely have to wipe off some grease/oil before even seeing it.
                          also look at post #4 of this thread showing a stamped number.
                            ok will report back
                              yeah, most definitely a Stude V8 Looks just like my water pump cheers jimmijim
