Sound and heat deadening
  • Sound and heat deadening
    I did a search and I could only find one thread on Dynamat. There were some suggestions there on eBond or something like that.
    I was curious if there was more options nowdays that you guys are liking?
    I need both heat and sound deadening. What is the best bang for my buck?
    Take a look at Lizard Skin. I"ve not used it (yet), but it sounds good.
      i used this on the avanti:
      http://www.ebay.com/itm/SALE-1-4-4X6...item1e6ce7b2e5
      i was very happy with the results, and the price was much lower than dynamat...
      they also have a thicker mat now, and for you, Kelly, motorcycle stuff!!!
      p.s. - i don't know this guy, and your shipping costs will probably be higher (NC to CA)...
      like Mr. K said, lizard skin is great also... but a little pricey for me.
        Bob, I like the simplicity of the Lizard Skin, but MAN is it pricey. You need a special gun to spray it on at about $100.00, then there are 2 different formulas you need to get the sound deadening and one for the heat protection. You have to stack them on top of each other to get both effects. A 2 gallon pale of each cost over $150.00 ea. and they only cover about 40-45 sq ft. No where near enough to do inside of doors, fire wall, floor, back wall, and inside the roof. So about $400.00 still wont cover and they only come in 2 Gal pales so now to get enough to cover or even more than I need is another $300.00...I am not spending $700.00.
          I've used a lot of Dynamat through the years. It does a great job but it's expensive. I buy the bulk packs through Ebay. Eastwood now makes a similar product that's cheaper than Dynamat but I haven't tried it.
          Scott Rodgers
          Los Angeles
          SDC Member since 1989
          \'60 Lark HT
          \'63 Wagonaire
          \'66 Frankenbaker
            I too like the "Lizard skin" method but agree on the pricey part. I ended up searching for a similar alternative. And found Hy-tech a spinoff comany from NASA. uses pretty much the same stuff as Lizard skin but WAY less expensive.
            http://www.hytechsales.com/prodsc.html
            Mark Chance
            1933 Model 56 5 window Coupe
              I just put this in my Avanti. http://www.b-quiet.com/extreme.html Installation was easy, just cut, lay down and shape to fit. It really sticks, once it is down, it is down forever. I recommend it. They have two different grades, I used the less expensive one. Today I drove the car for the first time with the mat and carpet in. I could not believe the difference. Really quiet. I was amazed. It took the 50 sq foot roll to do the floors. Here is a pic.
              John
              1963 Avanti R2
              Marshall, VA
                I have used Lizard Skin, and was happy with the results. I also used a closed cell dense foam under the carpet. I got mine from Loews, in the carpet section......listed as anti fatigue mat.
                Bez Auto Alchemy
                  Michael Myer used 3M rubberized undercoating under all surfaces on my body (inside fender wells & under floor pan) to help with sound deading. Then we used Lizard Skin to reduce heat and sound inside the body by spraying on inside of firewall, floor pan and inside the doors. Of course this was all done before anything else had been installed inside the interior.
                  John
                  63R-2386
                  Resto-Mod by Michael Myer
                    Here are 3 products i found and ordered, in my recent search, all at much better prices than the name brand stuff.
                    hope that helps.
                    Started with this (fatmat) today, seems good, and way cheaper than dynamat.
                    http://www.fatmat.com/
                    Check the test results link on this site.
                    http://www.lobucrod.com/
                      Kelly, why dont you & I get together in June & go to the L.A. Roadsters show in Pomona. They have tons of vendors there showing all kinds of newest & greatest stuff plus with the swap meet area it makes an all day thing. Fathers day weekend usually. I took Joy once & she couldn't handle even half of it.
                      60 Lark convertible V-8 auto
                      61 Champ 1/2 ton 4 speed
                      62 Champ 3/4 ton auto
                      63 G.T. Hawk R-2,4 speed
                      63 Avanti (2) R-1 auto
                      64 Zip Van
                      66 Cruiser V-8 auto
                        Hey you guys. Google e-dead that should send you to a firm in florida, cant remember the name, it is the same product as dynamat at about 20% of the cost. It comes with no name on it available in multple thicknesses, I do an entire car for a couple hundred dollars. I will look up the name on monday if you dont find it. Allen
                          I have found FatMat and RattleTrap that both seem pretty close to DM and about half price. Th eDead stuff is only for sound not heat and this truck gets HOT inside. The eDead is also not 20% the price, it is about 50% the price. It goes for 2 bucks per sq ft. and DM goes for about 4 buck p/sq ft. The FatMat is only $1.50 p/sq ft/ Best deal so far I have found.
                          http://cgi.ebay.com/100-Sq-Ft-Sound-...efaultDomain_0
                            I bought some FatMat off eBay for my Avanti, 100 sq ft for about $140 including shipping. It is identical to Dynamat. as others have said at half the cost or better.
                            Jim
                            their Memorials!
                              Read alot about this one on the HAMB. Probably going to go this route when its time.
                              1960 Lark VIII Regal Wagon
