Headrest
  • Headrest
    I have a 62 GT that I am making into a daily driver. Has anyone ever added headrest to the stock seats.
    The factory did!
    Miscreant adrift in
    the BerStuda Triangle
      The factory did!
      Miscreant adrift in
        The factory did!
        But just try and find some! [}]
        Clark in San Diego
        '63 F2/Lark Standard
          The factory did!
          Clark in San Diego
            I think I have a set, but you have to have the seats for them to go on. I have taken them to several swap meets but never could sell them.
            Leonard Shepherd
            http://leonardshepherd.com/
              Leonard Shepherd
                I would like to use my original seats. I know some type of internal bracket would have to be made and the upholstery shop would have to do some work at the top. Just hate to trade out the seats and than have a lot of work to get them to match the back.
                Leonard Shepherd
                  Leonard Shepherd
                    I've got ONE around here someplace. The seats they fit aren't special as far as I know, but you DO have to have THE correct headrest bracket to work with your seat.
                    The exposed part of the bracket ends up sitting on top of the seat back frame and secured to said same with two sheet metal screws (you have to drill the pilot holes for the screws). It's the lower end of the bracket that's critical - critical in that it has to have just the right "reach" ( length ) to catch and engage the big crosswire that makes up part of the seat back.
                    Rambler obviously used the same vendor for their headrests as the bracketry's the exact same style, but of a different length. I'm saying this because you could buy one thinking it was correct only to find out it wouldn't fit your particular application.
                    Miscreant adrift in
                      Miscreant adrift in
                        When in doubt, hot rod it out. I'd find a local trim shop that does some mild custom work. I've always been partial to the Chrysler headrests used between '68-'71. I wouldn't worry that much about it though, as your teeth will have a good bit on the steering wheel before you get whiplash.
                        Tom - Valrico, FL
                        1964 Studebaker Daytona - 289 4V, 4-Speed
                        Tom - Bradenton, FL
                          Tom - Valrico, FL
                          Tom - Bradenton, FL
                            I have added a three point seat belt to the car. I have eaten a stearing wheel once, do not want to do that again. I like those headrest also. I have a place I may take it when I am at that point and have theem come up with something. They do a lot of custom work.
                            I have seen kits for early Mustang.
                            Tom - Valrico, FL
                              Tom - Valrico, FL
