If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
That's the body tag, applied after the cabin was welded together. The top line is the Model, ending in K7 for top of the line hardtop. The bottom line is the sequential number of the weld job. This number does not indicate the sequence of the building of the vehicle. Thats sorta random. There were less than 2000 '64 Hawks built.
Sorry 'bout the K7, I misremembered.
Reason: Correct K 6-7 error
I have owned it only since December. The car is in New Branufels at A&E Classic Cars for brake work. The body tag on the cowl is 501, I thought this was the trim number the tag numer is 64V-K6 and then 501 am I wrong?
/Cut/The body tag on the cowl is 501, I thought this was the trim number the tag numer is 64V-K6 and then 501 am I wrong?Thanks , Mark
Yes, it is as Tom said Body Number only, means very little except the Body Tub weld-up line Sequence, NOT about the total Car.
The Serial Number on the left Door Post tells us which Car in the Final Line build sequence it really is, but you must give that number to the Studebaker National Museum to purchase any more info like Interior, Exterior Colors, Optional Equipment, Build Date, Shipped to etc. on the production Order, which will tell it ALL!
These Serial Numbers on '50's and '60's Cars are NOT VIN numbers, only Serial Numbers, before VINs were created.
Welcome Mark, to SDC and to the SDC Forum! You have quite a rare and desirable Model of Studebaker there.
Thanks , Mark
You are correct with the 64V-K6 for a 1964 V8 Hawk (not K7, as Tom B stated).
1964 six cylinder Hawks (export) were 64S-K6.
Your body was 501 out of the 1548 V8 Hawk bodies built for 1964 (not the 501st car produced). The 224 six cylinder Hawks for 1964 would be a different series of body numbers (see above).
