Hi All , My name is Rudy and i have aquired a 63 Lark . It has no motor or gearbox but all trim and cosmetics interior and exterior are there including a original set of hub caps . The model on the tag is 63V-Y6 .The front and rear windows are missing ,are these readily available ( can any SA members can help ) . I plan to to drop a Chev 308 ci and Trimatic Gearbox in . If i can find a Stud motor and Auto box and will use that as i like to keep my cars original
Studebaker Lark Windscreen /Rear and year idetification
Welcome to the forum Rudy. The windshield (windscreen) on your Lark was used on all Lark models in 63. However, in 64 it was used only on wagons & convertibles & in the final years (65 & 66) used in wagons only.
The backglass was 63 only on (Y,F & J) 2&4 door sedans & 2 door hardtop modlels. Hope this helps you in your search.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
No stupiid questions here. Lotsa stupid answers, though.
To avoid asking a question that has been asked before and gain access to the wisdom of previous answers, you can try the search funtion. Also, there are links to a lot of data and advice on the SDC home page (link at top of this page).Skip Lackie
Welcome to the Forum: First V8! I'm Bearhawke over on the AMC Forum.--------------------------------------
Hi 1962larksedan, Thanks it was at your advice that i joined here ,good also to have a fellow AMCF member to discuss issues with . I read your thread about the Lark and was inspired by the fact that you could drop a Chev motor and box in , as the one i have has none of this . The Lark is already restored minus the motor and box .Does the 308ci motor have the same mounting spacing's as the 350ci. Ill also take Skip Lackie,s advice and do the search first as im sure its been discussed .
Regards
Rudy
Originally posted by First V8 View PostHi 1962larksedan, Thanks it was at your advice that i joined here ,good also to have a fellow AMCF member to discuss issues with . I read your thread about the Lark and was inspired by the fact that you could drop a Chev motor and box in , as the one i have has none of this . The Lark is already restored minus the motor and box .Does the 308ci motor have the same mounting spacing's as the 350ci. Ill also take Skip Lackie,s advice and do the search first as im sure its been discussed .
Regards
Rudy--------------------------------------
Company I work for used to source Studebaker windshields (and many other older model windshields) from South Africa made by Safevue. Not sure if they're still in business or not. It was good glass. They may have been bought out by another glass company. If you find the company you will be looking for an American NAGS number of W638. Good luck. Not much hope on the rear window. Those are not reproduced. Can always be purchased here used, and shipped. Does it rain there much?KURTRUK
