Offy 4bbl manifold for V8 - don't see these often!
  • Offy 4bbl manifold for V8 - don't see these often!
    Check it out on eBay:
    http://tinyurl.com/2p9su4
    Wouldn't that be sweet for the vintage rod treatment?
    Clark in San Diego
    '63 F2/Lark Standard
    With some work, you can make it pretty.
    With some more work, you can make it accept an AFB.
    But it will always have real small runners, as it was designed for the small/small Stude V8.
    Great for a mild street car, but a stock Stude 4bbl intake will outflow it.
    DEEPNHOCK at Gmail.com
    Brooklet, Georgia
    '61 Hawk (project)
      Brooklet, Georgia
      '61 Hawk (project)
        There's also no entry point for the choke heat tube, but that wouldn't be a problem today with electric chokes.
        Thanks for pointing out the limitations, Jeff. (BTW, that's a nice polishing job!)
        Clark in San Diego
          Clark in San Diego
            black56hawk wrote -
            quote:Aside from any issue about the runner sizes, the entry angle of the lower runners into the head ports looks awfully restrictive to me
            Take a look at the front lower runners on an OEM manifold! Worse!
            All in all...they're really good around town (small runners!) on a 259. On the freeway..up to about 4000 rpm...not bad either...after 4000rpm....not much there at all!
            I've got two...one on my stock (engine) 259 Lark wagon. The other's sitting on a shelf.
            They can be opened up to a nice size, plenty-o-metal...but it'll cost a proverbial "arm and a leg"! Extrude Hone isn't cheap.
              black56hawk wrote -
                Actually there is a little hole that looks like it's intended to pass a small steel tube through for choke heat - but the only carb I ran on my offy manifold was an electric choke model so I never tried to make it work.
