Originally posted by ken-renda
View Post
63 Avanti R2 Parts
I understand the frustration of trying to locate an original R2 engine or even finding out the disposition of it. My Avanti 63R-2333 came with engine RS-1591. I've been seeking info for two years now about whether this engine still exists or not. Haven't gotten a clue yet.
Originally posted by bezhawk View PostThe spacing is the same....width wise on R3 manifolds. However the center ports have a round pipe plug screwed in that blocks the heat riser passeges(in the heads). The R3 end ports (main branches) are much different than standard heads.
The ports are much much taller and if you tried to bolt up a R3-R4 manifold to stock heads, the ports would be uncovered and it wouldn't run!!!
There are aftermarket R4 LOOKING manifolds made to fit standard heads, but, they are not R4 just because there are two 4 bbl carbs.
Originally posted by packardHawk58 View PostJust interested to know, that if you have a dual quad manifold on a Stude engine does the manifold's runners match the standard Studie R2 heads or do the heads have to be R3 B heads which have a wider spacing on the middle two runners.
http://forum.studebakerdriversclub.c...umber-Question
Originally posted by studefan View PostJeff, can you provide the engine number on that JTS please? Jeff
Originally posted by 63r2 View PostBrian
I assume they fit the standard motor.
I'm sure one of the boys here has installed the R4 manifold on a standard 289 motor (unless it is not a factory manifold).
Next time your talking to Duane ask him. It's on his 64 Conv.
Jack
I drove an R4 engined Avanti 3 weeks ago . Obviously it was a Grannatelli installed version in the 70's but non the less a complete R4 serialled motor.pb
You might want to give the Myers or Solanki a call. At one time they both had engines or they can refresh yours.
http://www.myersstudebaker.com/
http://solankiperformance.com/index.html
Brian
Jack
pb
This seems odd to me. The engine in my factory numbers match R2 Avanti Serial number 63R1653 has engine number RS 1322.
I wonder if the factory numbered R1 engines in a different sequence to the R2's ???
Peter Sant
KOOL R2
Ken,
I have a legit JTS engine that is currently hooked to a Powershift, but was originally a 4 speed GT Hawk.
I have a later supercharger and brackets, but am missing the proper water manifold and some other small pieces.
If your search does not turn up a good prepped R2, then this JTS might make a good starting point to rebuild one.
Originally posted by PackardV8 View PostHi, Ken,
FWIW, beware of patched together junk. From what you say, you are doing your car correctly. There many wannabe R2s in Larks and in garages which come on the market if the price is right. Know what you are looking for or take someone with you who does.
The R2 engines are out there; all it takes is money. To build an R2 long block correctly is at minimum $3,000 and then another $3,000 for the rebuilt supercharger and bracketry, carburetor, oil pan and show quality chrome.
Jack, the current engine is R-1322, I'm told it is an R1 engine,
Originally posted by PackardV8 View PostKen will have to confirm this, but his original post didn't specify which engine, if any, is in his Avanti at present. If he's building a correct show car, he'll want an R2 block with the correct serial number. If he just wants one which runs like an R2, any 224", 259" or 289" block will get him there.
only adding this because anything on the internet usually comes up on some search and gets passed around as mis-information; there were no factory Avanti R4s. I've seen a couple of Avanti with R4 intakes installed on them, but never seen a true R4-serially numbered engine in an Avanti. Your results may vary.
Originally posted by bige View PostIf it's an Avanti engine in there why not build it to R2 specs since the original engine is not available?
"The original engine is RS-1519 but there little hope of finding it."
Shouldn't an original R2 engine number be an RSJ prefix?
ErnieR
