carb selection
  • woodysrods
    Originally posted by Kurt View Post
    Which engine?? 259 or 289 would do well with factory AFB. I have an aftermarket Edelbrock AFB clone on my slightly warmed 289 and it works great. It works well "out of the box" Even better with some tuning. 224 or 232 probably need a smaller carb yet.
    Hi Kurt
    Which carb did you use 1406 600 cfm or 1403 500 cfm?
    And how "Slightly Warmed is your 289. What did you do to it?
    Good Roads
    Brian
  • DEEPNHOCK
    Only diff would be the carb angle (built into the intake), and the choice of a manual, or electric choke.
    The angle is so minor, I wouldn't sweat it.
    Just run a small AFB (1406) 600cfm w/electric choke
    Trim off the bottom half of the throttle linkage.
    Block off the heat crossover port.
    Use an aftermarket air cleaner.
    Use the fibre heat resistant intake gaskets (the steel ones are not as good as the fibre ones, especially if the intake is off another engine.
    Open up the secondary ports a little to clear the secondary throttle butterflies, or use a heat soak stacked gasket set.
    Go have fun,
    This is a very common swap.
    There have been dozens of post's and threads on this forum about all the little details.
    Do a good search and read up on it.
    It makes for a great driving improvement.
    Don't be askeered... Go for it!
    HTIH
  • Nelsen Motorsports
    I LOVE Carter carbs, rebuilt the Edelbrock one on my 383 MoPar and after only setting the floats it fired right up and ran like a charm! Thing is that this carb was last calibrated for a 400 Pontiac. Now that is a 750 CFM pot on an engine 100 cubes larger, but the 500 CFM should do the job for you.
  • Kurt
  • al2stude
    started a topic carb selection
    carb selection
    I'm converting to a 4bbl carb on my C cab pickup 259 cid using a manifold from a 289 eng. First, can I do this & what other carbs will do the job besides the WCFB Carter?
