Photo needed of the correct battery location in a '40 Champion
  • Photo needed of the correct battery location in a '40 Champion
    Chris Dresbach
    Ahhh.. The ole Slippery Slope..
    What started out as swapping on a new hood on my '59 truck, snowballed into a full restoration. Upgraded to a V8, bought a better cab and doors, front end rebuild, and on and on.. Now that the '58 Commander is almost running again and the Stainless Biz is established, the truck will finally come home and work will start back on it.
    Just be forewarned.
    And good on you for wanting to do things right.
      This should do it. This happens to be a '39 but under the hood it is identical to the '40. If you note the ground is to the firewall. I can tell you from experience that it is not good. For a non-show car I would strongly recommend you ground it to the block or cylinder head.
      Richard Quinn
        Thank you very much!
        Chris Dresbach
          You know, i thought i knew quite a bit about automobiles, but i've never heard of a blcok?
          This should do it. This happens to be a '39 but under the hood it is identical to the '40. If you note the ground is to the firewall. I can tell you from experience that it is not good. For a non-show car I would strongly recommend you ground it to the blcok.
          Evan Davis
          Prince Albert, Sk
            "Advanced Thinking"
            I have to say the '40's have to be from the "advanced thinking at Studebaker Corp." as I believe most other Cars of the Day had that crazy "Battery under the FLOORBOARD" thing going on!
            I remember my Dad's '53 Chev. Pickup still had that under the floor Battery with a Mechanical Pedal coming out of the floor, to the Right of the Gas Pedal, that directly engaged the Starter!
            And my Uncle's '56 Buick still had one of those Ancient old VACUUM Windshield Wipers!
              My '57 Cadillac still had vacuum wipers, crank windows and no radio!
                here's mine...
                haven't got to much clean-up yet...
                  Kerry,
                  The original ground strap in Richard's picture looks more appropriate than the cable in yours. Per his suggestion, I would add an additional ground cable in an unobtrusive spot from the lower firewall to the block. That would keep it looking original and provide additional security.
                    Chris, any chance you can build a new battery box in you school's shop class? I recall my high school shop class having a metal brake, a shear, a spot welder, MIG and TIG welder, etc.
                    In the middle of MinneSTUDEa.
                      Kerry,
                      yeah, i noticed that when i saw the pic. i'll have to find the "correct" neg. cable on my supposedly "correct already" car...
                      will definitely do the back up ground also... done that way too many times already w/fiberglass corvettes and the avanti ...
                        IIRC, the 1956 Continental Mark II also had vaccuum wipers. A prime case of Henry being 'cheap'; even on a $10K car, which was the most expensive US-built car when it came out.
                          Had a 57 Lincoln with an under the floor battery. It took a contortionist on steroids to replace it.
                          Don Wilson, Centralia, WA
                          40 Champion 4 door*
                          50 Champion 2 door*
                          53 Commander K Auto*
                          53 Commander K overdrive*
                          55 President Speedster
                          62 GT 4Speed*
                          63 Avanti R1*
                          64 Champ 1/2 ton
                          * Formerly owned
                            Not a chance. My school got rid of auto and metal shop with "budget cuts" a couple years ago. All they offer now is wood shop. I take wood shop now basically just for fun but it's just not auto shop...
                            Chris Dresbach
