Pictures of 53 Commander duel exhaust??
  • Pictures of 53 Commander duel exhaust??
    Hi Guys,
    Finally got the 53 Coupe body on the 59 frame. I'm hoping to find pictures of a duel exhaust system that deals with the "bat wing" support. Thanks for your help!!
    Regards,
    John Brayton
    John Brayton
    Call Don Simmons at Silvertone. Save yourself the grief.
      I "dueled" with DUAL exhaust in a 54 Champion (that I converted into a Commander).
      I would say that 55 exhaust (dual)would be your best bet.
      Bez Auto Alchemy
        There's pics of a '55 dual exhaust on my web site, including my attempt to replicate the one special hanger you eed on the driver's side. You may also need a '55-57 dual exhaust rear gravel shield, not sure if the pipes will clear the '54 one. (pics of that on my web site too)
        What engine/trans are you using? You may need to mix 'n' match pieces if you are not staying stock.
        edit: just reread OP and we are dealing with a '58 frame. Is this frame keeping the original gas tank? If so I would just get a dual exhaust for a '58 and use the '58 gravel shield. the '55-57 duals are odd because the driver's side tailpipe actually runs under the frame rail because the car was never designed for duals. Oddly, the '55 tailpipes are larger diameter than the 56-57 ones, but are the same shape.
          The exhaust just loops over the bat wing, or at least it did on the 55 I just took off. I have pictures of my 53, but it dosen't have the batwing. Want me to post?
            The frame is from a 59 Silver Hawk as is the floor and gas tank, the trunk is from a 56 Hawk, the engine is from a 62 GT Hawk and the remaining car is 53 Commander. I'm using the 59 bat wing and was hoping to see a picture of the "dual" exhaust installation. Thanks for the help and please post any pictures you think will be useful. My email is johnbrayton@att.net
            Regards,
            John Brayton
            John Brayton
              here's two pages you might be interested in
              http://members.cox.net/njnagel2/fors...elshields.html
              http://members.cox.net/njnagel2/exhaust/silvertone.html
              there are three different tailpipe sets - '55, '56-57, and '58-64. '55 and '56-57 are the same save for diameter.
              there are two different driver's side head pipes - '55, and '56-64. (not counting 56J.) The '55 one is bent farther away from the starter as the 6V starter is physically larger.
              There are two different pass side head pipes - '55-mid'62 and mid'62-'64. The later ones are bent for more clearance around a full flow oil filter.
              I *believe* that the driver's side main exhaust pipes are all the same.
              There's at least two different pass side main exhaust pipes; don't recall the year break, but whenever they changed the Flightomatic to an under hood dipstick, the pipe was changed for clearance. I discovered this when trying to put an all '55 exhaust system in my '55 with '63 drivetrain. Whoops. (Don was very nice about swapping pipes out for me though even though the issue was my fault.)
              '55 mufflers are different from the others because of the larger tailpipes. I *think* all the other C-K mufflers are pretty much the same but don't quote me on that.
              I would definitely call Don Simmons and ask his advice for your exact frame, body, and drivetrain combination after you've looked at the pretty pictures and read the above.
              good luck
                Here's a few of my 53 while exhaust was being installed. They don't show everything very good. But they may be some help. I used the 55 rear valance.
                  Hi Guys,
                  The "pretty pictures" do help. Gives me an idea about the clearances needed underneith. Looks like Don Simmons is the guy to talk to and I'll call Don soon.
                  Regards,
                  John Brayton
                  John Brayton
                    John, you don't have a custom exhaust/muffler shop near?
                      Should mention, the '53, at least the early ones, had a completely different gravel deflector. Looking at the back of the car you couldn't even see it was there; no pipe clearance problem at all. These are Simmons duals on mine.
                      http://s57.photobucket.com/albums/g2...t=PB110002.jpg
                      http://s57.photobucket.com/albums/g2...t=PB110001.jpg
                        Yep, we've got some fine custom muffler shops in Sonoma County but I find it's better to have an idea what you want before you turn them loose on your car.
                        Regards,
                        John Brayton
                        John Brayton
                          Great color choice on your 53 Brad, beautiful.
