Flanged rear Axle
  • Flanged rear Axle
    I am trying to find rear (outer) bearings and seals for a 64 R3 I'm currently restoring. SI is out and local bearing company can't cross reference the numbers. I did manage to find Twin Traction clutches.
    Bez Auto Alchemy
    I don't know either but if you find a source, let us know.
    Ted
      Have you tryed this place? They have had every Studebaker bearing I have needed. http://www.alliedbearings.com/
        Don't the R3 flanged axles use the sealed '56 Packard Senior bearings? If that is true, Packard Parts suppliers should have some.
          If it is a true R3 flanged axle, try a forum search. I posted that info about a year back. They are available from a flaps. The kit is the same as a 1/2 ton Ford pickup of the '60's and early 70's, I think. Comes with seal, bearing and wedding band. I had to replace the right rear bearing on R3 5642. E-mail me if you can't find the post and I'll look up the kit number.
          Kit part number - CR 88128-R
            Thanks for the number.....couldn't find the thread.
            Had one guy I know searching online and found some for $600 each. I said Ha Ha Ha.......no!
            Bez Auto Alchemy
              Thanks for the number.....Ordered BRG 88128-R from NAPA 37.50 ea 77 Ford PU. (Also fits Mosier axles for certain 9" rears)
              Bez Auto Alchemy
