Ok ,I know im about to open a can of worms.I truly like the stude engines.But on the 'dare to be different ' side has any one ever dropped a 400 bb pontiac in a stude?I got a 2 owner 73 booneville with great drive line 400 bb 400 turbo trans.Any Opinions?
400 pontiac in a stude?
This topic is closed.
I've located a 54 c commander in south Ms.It has most everything but the drive train.It will need full recuperative(not restoration) interior rust removal etc.... ,but looks like a fairly solid car.My buddy said put it in the 61 hawk.I just gave him a hard look n said you gotta be drinking something stronger than pepsi.Maybe a 60s plain jane lark(super sleeper).Just a wandering thought in my feeble mind n thought i would get some input from more knowledgeable men than me.thx for the responseP.S. it has a 2 bbl carb on it n gets 19.6 mpg in that monster 4 dr bonneville ,really not lying.It will also bury the speedo n its like sitting in that big ole favorite chair you got
The overall design of the Pontiac engine is very similar to that of the Studebaker, though it only has 10 headbolts per side, cast rods and crank, Non-adjustable valve train(unless you install BBC studs), valve springs that coil bind easily and a few other quirks. Most people would not notice that it is a swap at first glance. The main benefit is that it has a much larger piston displacement, and is very torquey as a result. The engine mount bolt bosses are cast into the side of the block midway between front and rear, so you will have to build special frame mounts. But all that is good, since you intend to use the Turbo-Hydramatic, and a crossmember to support it at the tailshaft extension housing. The intake manifold/carburetor is kind of a high-rise design,compared to the Studebaker unit, so that hood clearance could be tight.
I saw a '61 Champ with a 389 stuffed in it at the POCI convention in Anaheim a few years back. It was a tight fit, but he did it without cutting the firewall!
Clark in San Diego:
Proud new owner of a '63 Lark!
Your car, your choice, just some thoughts:
FWIW, the Studebaker V8 is the second widest, tallest, heaviest post-50s V8 of its displacement I know of. This means any modern V8 will fit. We've seen Cadillac, Pontiac, big-block-tall-deck Chevrolets, hemi Mopars, Oldsmobile and many others successfully installed in Studes.
One thing to remember, the time, expense and labor of an engine swap is relatively the same, no matter engine what you put in it. If the Poncho is free and money is tight, then maybe it is where you want to go.
As many times as I have fragged the concept of belly-button SBCs in Studes, their popularity means more horsepower per dollar than anything else. Pontiac power costs two to three times as much as Chevy power.
As a thought, was at an orphan car show recently and naturally, there were several Studes. One nice '53 had a built 350/350 SBC and everyone walked by yawning. A GT Hawk had a 302 SBF and more yawns. A nice white '54 coupe had an R3 clone engine and the crowd around it was two and three deep most of the day.
Anyone want to guess what is physically the biggest outside, no bigger than a Stude inside V8 I ever tried to fit in a swap?
thnx, jv.
PackardV8PackardV8
I mess with Pontiacs occasionally and one day I had an odd idea and took a intake manifold gasket from a Pontiac and laid it onto a Stude head and guess what, it was almost an exact fit. So I thought maybe the intake would line up, but no go the stagger of the cylinders is opposite of the Stude!
Dan White
64 R1 GT
64 R2 GTDan White
64 R1 GT
64 R2 GT
58 C Cab
57 Broadmoor (Marvin)
Wohooooooo,
just got an e-mail this morning from Stude 53.It turns out hes just couple hrs drive from me in Ms.Hes got a studillac and I think I can get some great ideas from his car.Talking to him a couple months ago thru another member sorta planted the seed about swapping a poncho in a stude. I'm hoping i can get down there soon an get a close up view of his beautiful Stude.I saw some pictures of it he sent me.Thanks for the input guys,I think the seeds about to sprout.
A 455 Buick would be a good swap. If you throw an aluminum intake on one they weigh the same as a SBC. If you found a 1970 Vintage 455, you wouldn't have to do any mods to it to make it a scary ride. 510 ft/lbs of torque at 2800rpm would really launch a little Lark, wouldn't it?
Todd
63 Lark 2dr Sedan
