AFB question ???
  • AFB question ???
    Just acquired a 4 bbl manifold , carb and air cleaner off a ' 64 Lark, today. When I got it home I checked all the numbers out and the carb # isn't in the parts book but I find it on a Studebaker carb listing I have and it shows that # in this listing. The # is 3506S with A3 under it . Now I have another ' 64 set up and the carb # is 3726S and that one is in the book . Can anyone tell me what the difference is between these two carbs ....if any ? There doesn't appear to be any difference looking at them.
    It's a R1 carb, wanna trade for the stock one. <g>
    Studebaker News Group
    64 Daytona HT
    64 Daytona Convert.
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    63 R1 GT Hawk
    63 Avanti R1/AC
    63 Avanti R2/4 speed
    62 Daytona HT
    62 Lark 2 door
    60 Hawk
    JDP Maryland
      So whats the diffence....bigger jets?
        It's jetted richer and I think may flow a bit more. ( not sure)
        64 Daytona HT
        64 Daytona Convert.
        63 R1 GT Hawk
        63 Avanti R1/AC
        62 Daytona HT
        62 Lark 2 door
        60 Hawk
        JDP Maryland
          For carb questions...Jon Myer is the go to person.
            JP....I looked in the back section under jet thrust part numbers and the 3506S carb # isn't mentioned there either. You sure its a R1 carb ?
              That and 3726S were on standard 289s.
                Found by Googleing 3506S
                Carter Carbs Specs for R - Engines
                R1 - Carter AFB 1 7/16" primaries, 1-1 1/16" secondries
                model 3506s
                flow 625 CFM (+-10)
                Replacement = Carter CRT-9635 or Edelbrock 1406
                Jets: .089" (120-159) primaries;
                .058" & .069 (16-99) metering rods.
                Secondary jets were .077" (120-177)
                R2 - Carter AFB 1-7/16" primaries, 1-11/16" secondries
                Calibrated and sealed Stude# 1561641
                model AFB-3606
                flow 625 CFM (+-10)
                Replacement Carter CRT-9635 or Edelbrock 1406
                ( Use Procharger bonnet to adapt supercharger hose)
                R3 - Carter AFB 1-7/16" primaries, 1-11/16" secondries
                Competition model Stude# 1558637
                Standard model 1563050
                model AFB-3808S
                flow 625 CFM (+-10)
                Primary jet # 120-159 Size (.089)
                Secondary Jet # 120-166 size (.0935)
                Primary metering rod # 16-103 size (.068 X .060)
                float setting 13/32"
                R4 - Carter AFB 1-9/16" primaries, 1-11/16" secondries
                Front Carb
                Standard model Stude# 1563051
                AFB-3810S
                flow 675 CFM (+-10)
                Primary jet # 120-162 Size (0-1015)
                Secondary Jet # 120-176 size (.0635)
                Primary metering rod # 16-124 size (.069 X .0635)
                float setting 5/16"
                Rear Carb
                AFB-3811S
                flow 675 CFM (+-10)
                Secondary Jet # 120-122 size (.070)
                Primary metering rod # 16-204 size (.073 X .063)
                float setting 5/16"
                64 Daytona HT
                64 Daytona Convert.
                63 R1 GT Hawk
                63 Avanti R1/AC
                62 Daytona HT
                62 Lark 2 door
                60 Hawk
                JDP Maryland
                  Thanks JP...thats good info to have
