Call Red Line Gauges in Humbolt Tenn. Look them up on goggle. Ask for John. He can do anyting and he will tell you if and why a Stude would be more. I do know my 56 does not have a second hand and one of the two hands is a cap hand. This may be the reason. Just a guess. John can tell you. Let us know.
Borg Clock Confusion
'Can You use a 6 volt clock in a 12 volt car after you clean it"
YES, I have a 6 volt clock running in my son's 12 volt car. You need a dropping resistor in series to do so . J.C. Whitney sells same. Or was it meant as a "put down"?
...Dick
1950 Champion Starlight
1963 Hawk GT
Santa Barbara
CA
The 1950 Champion Starlight
Santa Barbara
CA
...Dick
1963 Hawk GT
Santa Barbara
CA
Santa Barbara
CA
No, it's not a voltage divider. It's a dropping resistor. A voltage divider has two resistors in series across the power supply, so that the reduced voltage (6 volts in this case) is obtained at the connection between the two resistors. Assuming the resistors are sized correctly, it gives a more stable voltage than a dropping resistor.
Frank Starr, P.E.
Seattle
Frank Starr, P.E.
Seattle
Frank,
You are more right. I considered the load eg. clock coil resistance to be the second resistor in series
with the "dropping resistor" to divide the 12 volts into 6 volts across it and 6 volts across the load(clock).
Dick Curtis
Korean War GCA radar repairman who should know better,The 1950 Champion Starlight
Santa Barbara
CA
Frank,
Dick Curtis
Santa Barbara
CA
