I am sure this has been touched on before, but was there an offical H-P number given to the R-1 engine? What was the difference from the standard 289? Did all Avanti's come with at least an R-1.
R-1 engine
245 HP, most of the increase from the wilder cam and 10.5-1 compression. It was the standard Avanti emgine.
64 R2 4 speed Challenger
63 R2 4 speed GT Hawk
63 Daytona Convert.
JDP Maryland
I don't recall the HP figure but, yes, all Avantis had an R1 or better. Higher compression in the R1 and a hotter cam - different from the standard 289.
1963 Daytona project FSNo deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
Lots of other differances, but very little to do with the HP increase. (You need to build a few Avanti powered clones to find out how many little parts are needed) i.e. left hand frame motor mount on a GT Hawk.
63 Daytona Convert.
JDP Maryland
Fuel pump is different (bigger) and lines are 3/8" not 5/16" should have a filter with a return fitting on it and a return line back to the fuel tank. Wouldn't be a bad retrofit to any Stude actually. Also dual point distributor and didn't most of the R-engined cars get a 40 amp alternator? Also clutch fan, harmonic balancer, the little oil baffle around the pump, and I'm probably forgetting some more stuff
62 Daytona hardtop
http://home.comcast.net/~njnagel--
quote:Originally posted by N8N
.... and I'm probably forgetting some more stuff]
Tom
1963 Studebaker Avanti, 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
63 Avanti R1 2788
1914 Stutz Bearcat
(George Barris replica)
Washington State63 Avanti R1 2788
1914 Stutz Bearcat
Washington State
