More questions on wheel rim sizes
  • #16
    Seems like it's more likely to be a 7" wheel, which if measured rim edge-to-edge will read 8".
    Dwain G.
    • #17
      Dwain G.
      • #18
        Leonard,
        I may be run out of town for not being "frugal", but I bought new 6" rims for my Daytona for $37 each. They are Hayes# 82552 or NWRA# X-40273. Fit fine, work with Turner disk brakes, and use the smaller "Studebaker" lug nuts.
        I am told that these were used on '83-'92 Ford 4X4 Rangers and Bronco IIs. Maybe the boneyard has one of these.
        Jim Bradley
        '64 Daytona HT "Rerun"
        Jim Bradley
        Lake Monticello, VA
        '78 Avanti II
        • #19
          Leonard,
          Jim Bradley
          Jim Bradley
          Lake Monticello, VA
          '78 Avanti II
          • #20
            I know its a little more, but new chrome reverse wheels from jegs 15x6 are 50 bucks a piece. pretty cheap for a new rim that would look great
            erin
            Erin Hays
            1961 Hawk
            1962 Lark
            1963 Wagonaire
            • #21
              erin
              Erin Hays
              1961 Hawk
              1962 Lark
              1963 Wagonaire
              • #22
                Thanks, All that helps a lot.
                • #23
                  • #24
                    Leonard,
                    You've got about $27 invested in those four wheels off the 5th Avenue. Before you go exchanging them, please note that they may be worth substantially more than that EACH.
                    Mopar police cars on that body sported 7x15 steel wheels (measured where the tire bead rides). They are about 8 inches across the entire rim. If those are what you have, there is a real demand amongst some of us with late Larks AND the Mopar folks.
                    So far as 6x15 wheels go, they were standard on lots of full sized Mopar cars of the mid/late 1960's and '70's. Furys and such.
                    Enjoy!
                    • #25
                      Leonard,
                      Enjoy!
                      • #26
                        Leonard,
                        The wheel Rerun makes reference to, X-40273, is also used on most all late model full size Ford Crown Vics., LTDs (full size only, not the fox platform) small Ranger pick ups (as BP states), and many other applications in the NWRA catalog..... or mabe on line? OBTW, IIRC, that # is the wheel Bob Helm sells new in TW. Remember when buying used, always take a tape measure for checking width and offset, a wheel stud circle guage, and try to get access to an empty front drum or rotor to spin em' on. Saves a trip to swap a bent one. Hope this helps.
                        Dan Miller
                        Atlanta, GA
                        • #27
                          Leonard,
                          Dan Miller
                          Atlanta, GA
                          • #28
                            I went to a local junk yard to look for wider rims for my 52 Commander. ...
                            Leonard,
                            If you didn't see this wheel data site that JP posted (somewhere) recently, it is MUST reading.
                            https://www.rsracing.com/tech-wheel.html
                            Museum R-4 engine
                            • #29
                              Leonard,
                              Museum R-4 engine
                              • #30
                                I have been trying to find a single rust hole in any of these cars in your pictures. Can't. Is that what life is like outside of Michigan?
                                It boggles my mind. That yard has better stuff than most of our used car lots.
                                Dan
                                52 hardtop
