Provincial proddings
  • Provincial proddings
    I've been trying to get the Provincial's floor ready to recieve some fibreglassing and also trying to rustproof some areas that will be closed up/covered up eventually.
    The PO let this car set with it's original, rubber matting in place for years. This while the car was covered by a "tarp" that did more to hold moisture in than keep it out. The jute backing on the rubber matting was an excellent nursery for tinworms to incubate and feed. Consequently, this "California Car" has some rust in it's floorboards. Even a bit in the front too as carpeting served to play sponge when shrunken door seals let rain find it's way inside.[V]
    The rear floors are a bit of a challenge as I want to anchor seat belts there and there's not much left to anchor to![B)] I'm thinking of a sub-floor bar (crossmember, if you will)that would attach to the frame rails on either side. Easy enough EXCEPT for the damned driveshaft and it's floor hump. Another approach is a heavy, triangular plate that would fair into the frame rail aft of where the belt mount points would be.
    I'm going for 3-point belts and the B-pillar part is easy. In fact, if the floorboards weren't so moth-eaten, I'd just slap a big piece of reinforcement plate beneath them and be happy with it. I DON'T wanna put new floorpans in this thing.
    [img] http://images.andale.com/f2/115/106/...55_RRFloor.jpg [/img]
    Another thing that I addressed was cleaning out in the bottom of the A & B-pillars. It's solid inside these but I can't, for the life of me, figure what was served by the body line when they obviously stuck the nozzel of the Dum-Dum gun inside the bottom holes of these pillars and squeezed off a large dollop into them.
    The stuff didn't lay down and really seal anything. After 50 years it's just IN THERE, like a fossilized pile of dog doo!
    Oh - it's STUCK to a good degree, but it sealed nothing but the bit of floorboard that it leaned upon. I spent a couple of HOURS digging it all out. Must've did away with 2 useless pounds of baggage!
    Note in both pics, you can see the little die-cut teeth that your windlace is held in with. You insert the tab of the windlace and then tap the tooth down to hold it fast.
    I had some places like that in the floorboard of the 51 I put POR 15 on then put fiberglass cloth on top of it while it was still wey then let dry for a little while then put some more over it. Dryed hard as a rock
        It would be nice to see that Provincial last a couple more generations, Bob.
        I'm afraid in the Northeast rustbelt I wouldn't think twice about new floor pans.
        Brad Johnson
        33 Rockne 10
        51 Commander Starlight
        53 Commander Starlight
          Brad Johnson
          33 Rockne 10
            I know what you mean. Thing is, out here - if they rust, they rust from the top down (if it's living too close to the ocean) or from the inside out (wet carpets & mats thanks to leaky seals and windows left down.
            Looking at this wagon from underneath, if it weren't for the few holes that have opened up, you'd think it was rust free. Dang frame looks really solid as do the body supports and all the related hardware. If only it hadn't set, covered up for 8 or 10 years - or someone had had the understanding that soaked jute padding was doing the car harm..........[V]
                Bob,
                There was a great thread a while back about adding seatbelts and issues with worrying about weak floors. The concern was upon impact, the washers might pull through. The hot-rod aftermarket has come up with some great solutions, and at a good price. It was a long thread. Hope you can find it.
                KURTRUK
                KURTRUK
                  Bob,
                  KURTRUK
                  KURTRUK
                    I took part in that discussion. Here's the link, to save everyone from doing a search: http://www.studebakerdriversclub.com...?TOPIC_ID=4370
                    [img=left]http://rocketdillo.com/studebaker/misc/images/Current_Avacar.gif[/img=left] - DilloCrafter
                    1955 1/2 Ton Pickup
                    The Red-Headed Amazon
                    Deep in the heart of Texas
                    Paul Simpson
                    "DilloCrafter"
                    1955 1/2 Ton Pickup
                      1955 1/2 Ton Pickup
                      Paul Simpson
                      "DilloCrafter"
                      1955 1/2 Ton Pickup
                        Hey Bob - You could slap a piece of reinforcing plate over the weakened pans AND fiberglass 'em. Would add the strength you need without the cost or hassle of replacing the pans. 18 gauge should be sufficient. (ME, giving YOU advice! HA!) <G>
                        Western Washington, USA
                            Mr. Biggs,
                            When I mounted the 3 points in the front of our Provincial the outer mounts (with the retractors) ended up just inboard of the B pillars, and the reinforcement plates underneath had one edge overlapping against a body to frame gusset. The inner mounts ended up on the lower edge of the driveshaft hump, just to the rear of the driveshaft center support bearing cross member.
                            I have some pictures if needed.
                            Ross.
                            Riverside, Ca.
                            1957 Provincial X2
                            1958 Transtar
                            1963 Lark. F.S.
                            Ross.
                            Riverside, Ca.
                            1957 Provincial X2
                            1958 Transtar
                              Mr. Biggs,
                              Ross.
                              Riverside, Ca.
                              1957 Provincial X2
                              1958 Transtar
                              1963 Lark. F.S.
                              Ross.
                              Riverside, Ca.
                              1957 Provincial X2
                              1958 Transtar
