Here's a question for you. Can anyone tell me what the difference is between '62 and '63 Hawk grilles? My car is a '63 and the grille shell on it is in sad shape. I just bought a decent used shell that was billed as a '63 by the seller. When comparing the newly acquired one with the one on my car I note a slight difference at the bottom corners of the grille shell. The one I just got has a little section notched out on each side which will reveal a bit more sheet metal - not much but definitely different. I want to have one of these restored and rechromed and I suppose it may as well be the correct one - or are they both correct? Was there a running change? I can't see what functional difference it would make. I'm wondering if these are from different years and also whether my car had the correct grill on it when I got it. The rear applique is from a '62 so maybe the grille is as well? Before I buy an NOS mesh I want to be sure it will fit the shell I have restored as I notice that '62 and '63/64 meshes aren't offered as being interchangeable or was it not a matter of fit but simply of a slight styling difference??? Thanks.
HUB (puzzled in S.W. Ontario)[?]
