'56 Hawk Help...
  • '56 Hawk Help...
    quote:Originally posted by OzarkPetunia
    Heeellllooooooooo!
    We're finally reassembling the Super Coop after a VERY long nap (burned valves on the 185 on the way home from Cedar Rapids) and I need some help figuring out which doohickeys are turquoise vs black vs metal.
    Pretty please?
    Oil breather cap, coil bracket, throttle linkage, fan & water pump pulley, generator adjustment bracket... I'm sure I'm missing a bunch...
    And when I got the car the oil filter canister was mounted on the right fender but we've gotten a bracket and hoses to mount it on the engine. Does anyone have some fabulous pictures of how it's mounted and how the hoses are routed?
    Thanks for any help you can offer!
    ~Rose
    Fayetteville, AR
    Any help would be appreciated.
    Originally posted by Ozarkpetunia in the tech section.
    http://forum.studebakerdriversclub.c...TOPIC_ID=40846
    From deep in the Ozarks...
    Fred
    I found these pictures, but the engine compartment doesn't look complete...
    http://www.ecarlist.com/showroom/133.../363132#51.jpg
      This doesn't look quite right either...
      This is from a 55 Champion.
        I guess you know your Block, Valve Doors and Head should be Studebaker '56-'57 Turquoise Green as you did not ask that.
        The Fan, Fan Pulley and Gen. adj. arm, Water Pump, Bell Housing, and Transmission also.
        This '55 has good looking gray steel linkages and Coil Bracket.
        Your Oil Cap, Spark Plug Wire Raceway, Coil, Generator, Starter, Volt Reg. all should be Gloss Black.
        Oil Filter bracket black, Filter case Fram Orange, lid gloss Black.
        Incidentally, this '55 Engine should be dark Blue, not Black!
          The 56 era gloss black is today's satin black, DO NOT use gloss black, it will be too much gloss
          It is an addiction!
          It is an addiction!
            THANKS!!!!!!!!!!!!!
            I got home late fom work and a great big elf has put a bunch of stuff back together! I bet he thinks he'll get to drive it once in a while...
            Fayetteville, AR
              Sounds like we are close! The fan and pulley are currently black[:0], so I guess now is the time to change them to turquoise...I need to replace the upper generator bracket as it has a crack in it.
              So all the linkage and the coil mount are supposed to be steel gray? I got as much rust off of the mount as I could, the inside is a real pain...but all the linkage is clean! What's the best thing to coat the bare steel parts with so they won't rust again? I've got some aluminum color paint and clear.
              Distributor I'm guessing is also black?
              Thanks for the replies! I hope the weather holds so I can get more done tomorrow evening and we can fire her up on Saturday!!
              Fred
                We're rootin for ya. Hope all goes according to plan.
