Mounting carb to manifold worries.
  • Mounting carb to manifold worries.
    Set my afb on top the manifold,to find out it rocks a bit.first thought was the carb must be warped? is it fairly common to see this,I do have a stack of gaskets that came with carb,so do I mount it and not worry. thanks for advise!
    Joseph R. Zeiger
    Joseph R. Zeiger
    Joseph R. Zeiger
    Did you check the base of the carb to make sure there isn't anything on there, like leftover gasket?
    Chip
    '63 Cruiser
    '57 Packard wagon
    '61 Lark Regal 4 Dr Wagon
    Chip
    '63 Cruiser
    '57 Packard wagon
    '61 Lark Regal 4 dr wagon
    '50 Commander 4 dr sedan
      Hey Chip, no this is all new re-built.set it on to see what for heat tube I will bend up.and noticed it is a little shakey.might not be a problem just never ran into this before.
      Joseph R. Zeiger
      Joseph R. Zeiger
        Lay a straight edge across both surfaces. Like a 12 inch scale or ruler. I have had to lap a few manifolds in before with a big file.
        http://ozarktrails.tripod.com/
        Studebaker Diners Club
          Do some investigation before you go ahead and bolt it down. Carburators don't have a lot of give. If you snap one of the ears off, it will ruin your whole day.
          Doug
          Venice, Florida
          1950 Champion
          9G F1
            Joseph-
            Are you just setting it on top or are you dropping it over the studs?
            My guess is that it's getting hung up on the studs.
            http://community.webshots.com/user/s...host=community
              Will, just sitting on top with no studs.
              Joseph R. Zeiger
              Joseph R. Zeiger
                Find the cause of the rock before securing it. It might be important.
                Tom Bredehoft
                ....On the road, again....
                '05 Legacy Ltd Wagon
                All Indiana built cars
                  If the carb doesn't sit flush on the manifold, find out why before trying to tighten the mounting nuts. I seriously doubt that the manifold is warped, but the base of the carb could be. Was the carburetor recently rebuilt or is it a used piece as there could be left over gasket material stuck to the bottom of the carb causing the problem? Bud
                    This is an AFB manifold, right?
                      The key question is, exactly how much is a "bit"? 10 thousanths' irregularity, no problem; quarter-inch, problem.
                      For the effort it takes to correct, I would be sure to do so. You face a possible lifetime of vacuum leaks and/or snapped off carb ears. Not worth the risk IMO.
                      Parish, central NY 13131
