64-66 inner fender sheet metal question
  • 64-66 inner fender sheet metal question
    Hi guys. The inner fenders on the 64-66 are 3 pieces welded together. I have heard the piece behind the headlights on the dual headlight cars are hard to find.Any truth to that? Thanks!
    Ask Ed Reynolds as SASCO may have had some in stock.
    SnowLark
    In the middle of Minnestudea
    In the middle of MinneSTUDEa.
      Yes, SASCO was out of them quite a while before they closed.
      Also many used ones are rusted out or mangled and can't be used for spares.
      The three pieces need to be fitted to the car before welding.
        Could always consider switching to the '64 single headlamp style... I thought I read somewhere that those pieces were still around someplace.
        <h5>Mark
        '57 Transtar Deluxe
        Vancouver Island Chapter
        Mark Hayden
        '66 Commander
        Zone Coordinator
        Pacific Can-Am Zone
          The headlite mounting panel can be converted to dual can it not ? I have not looked at them side by side in a while. I was thinking there is enough material to do so.
          Tom
            ...yes you can convert the single to dual with some art work...
              Hi I have purchased a set of single head light pieces from SI,as my fenders have the dual lights,these are good used condition,no rust.
                I also think there are 2 types for dual headlights because some had brackets at the bottom for weights on convertibles and possible slide roof wagons.Ed
                  I think the weights mounted on the grill panel.
                    I picked up some parts when SASCO was closing and was looking for those panels, I think they're called air deflectors.
                    Dennis told me they only had one side left(for dual headlights), I can't remember which side it was but I bought one.
                    John V.
                      The "weights" on the convertibles (at least the 62's) are bolted to the front nose panel. And they are NOT fun to install by yourself! LOL
                      Jim
                      their Memorials!
                        Behind that grill panel for the convertibles weights, attached to the front inner fender panel, are two sheet metal brackets that are either spot welded, or just welded on. They don't just hang on the front panel. The long weight bolts hold it all together through the front panel, weights and those brackets on the inner fender to diminish any cowl shake.
                          We are actually talking about the "Baffles" or "Air Deflectors", these are BEHIND the headlight buckets and WELDED to the Inner fender, and one side or both are now NLA.
                          The '62-'63 grille PANEL is related somewhat to this discussion, but not '64's and yes the 2 Hd. Lt. '64 [u]GRILLE</u> can be converted to 4.
                          On '62-'63 Larks, the Convertible/Wagonaire WEIGHTS are on the FRONT PANEL. on '64's they are on the lower chin pan (stone pan).
                          Nomenclature, it'll bite you every time! Lol!
                            Here's the front of my 66:
                            Note that there is plenty of room to cut for the dual buckets, but that the hole for the single buckets is quite large - the excess area will need to be filled in.
                            Scott Rodgers
                            Los Angeles
                            SDC Member since 1989
                            '60 Lark HT
                            '63 Wagonaire
                            '66 Frankenbaker
                            Scott Rodgers
                            Los Angeles
                            \'60 Lark HT
                            \'63 Wagonaire
                            \'66 Frankenbaker
                              Anyone have a part number for the right side 64-66 air deflector? Thanks!
