Color on 63 Avanti R2 alternator
  • Color on 63 Avanti R2 alternator
    Just had my alternator rebuilt, I had the center section painted a dull red just like it was when I pulled it off. I have been told that this was incorrect, it should be a dull silver. Does anyone know for sure what this little section in the middle should be painted. I am not a stickler for detail, but since it is off the car and nice and clean, I figured, why not make it correct.
    TX John in VA
    1963 Avanti R2
    John
    1963 Avanti R2
    Marshall, VA
    I bought some NOS alternators and the center is a copper type color.Can ask my neighbor to try and post a picture since im not that technical yet if you like.Ed
      Well, I looked at the list:
      http://sterkel.org/avanti/articles/S...nti_Colors.pdf
      and I didn't see that part listed. So when you find out what it is the list can be expanded to 44 paintable items on an Avanti.
      Thomas
        I've not taken apart any prestolite alternators, but that "copper" or dull red color is most likely dipped insulation material. Having taken apart a '65 ford and some 80s ford alternators, I think they are constucted similarily.
        If you disassemble the alternator, the windings are wound on a laminated section (aka "lams") to form the stator. That is the center section. After the windings are done, the stators are either sprayed or possibly dipped in a shellac or epoxy material to both add electrical insulation and glue the wires to the lams so they don't chafe from vibration and potentially short. The exposed color of the lams in the center between the end bells will be whatever that coating is. I have seen some that are brown and also black on other brands. Could also be a dark yellowish clear over the bare steel of the lams. The end bells are bare aluminum, correct? So, the colors of the finished part depend on how the unit was assembled and what was or was not painted when and how. Last time I detailed a alternator, I painted the lams section semigloss black to match the color of the original dip that was thin and surface rusted on the outside and used detail aluminum casting paint on the end bells. Pulley and fan were tough since they were goldish cad plated. That was for a ford alternator and not a stude one though.
        Jeff in ND
        '53 Champion Hardtop
        Jeff in ND
          TX John in VA
          1963 Avanti R2
          It's a sort of shellac, gold/tan color
          JDP/Maryland
          JDP Maryland
            Are they aluminum castings or are they zinc castings?
            Brent's rootbeer racer.
            In the middle of MinneSTUDEa.
              It sure looks like an aluminum casting for the shell. I did go down and take a look at two Avanti alternators that are reported to be original/unrestored out of a parts bin. Both were painted a low sheen light gray, very similar to the gray wheel color of my 1979 Chev van/rally sport wheels so I think I will go with that. Easy to change if I we determine it should be of a different color. TX all for the help. One step closer to getting the 63 back on the road.
              1963 Avanti R2
              John
              1963 Avanti R2
              Marshall, VA
                JDP is correct on the color of the clear finish over bare metal. Rebuilders spray the stators with colored dielectric paint. The color hides the traces of rust remaining on the laminations.
