Starter selenoid 51 champion options
  • Starter selenoid 51 champion options
    I guess the selenoid for the starter is no longer available. Mine is on the starter. I guess I could order one that fastens to the firewall. Do you think NAPA would have a generic one I could use if I took my old one in to compare? Or do I just need to use the firewall one?
    1951 Studebaker Champion 2dr
    1987 Buick Grand National
    Napa probably does, but Chuck Collins sells a cowl mounted solenoid for your car, too:
    http://tinyurl.com/yehhnrv
      The one (assuming it's original) on the starter requires a ground be supplied to the little terminal to actuate the solenoid. Stude got away from using a grounding start signal during the '55 year. IF you're using the original start circuit, installing a later solenoid is gonna be disappointing in that as you engage the start switch - nothing's gonna happen.
      This CAN be remedied pretty easy, but we need to know IF the car's all original and whether or not you're using 6 or 12 volts now.
      1963 Cruiser
      1957 President two door
        Right now it's original and staying 6 volt. Down the road I might make the swap if I go with a gasser look and v-8. Now my goal is to getting it running and drive-able. Might need to do the cowl mounted one.
          Mike, I'm sure I have a good used one here. Gimmee a day to see if I can find one.
          1963 Cruiser
