Alternator conversion
  • Alternator conversion
    I have a 61 Hawk that has a Delco generator. I would like to convert to an alternator and swap out the amp meter for a volt gauge. What is the best path to take? I am planning on swapping out all the old SW gauges with new ones anyway. I will be using a Mallory Unilite from Dave T.
    Jon Kammer
    Have you looked at the technical tips on the SDC page?
    http://www.studebakerdriversclub.com/techtips.asp
      You want my Honda swap then, you just need a Stude alt mount bracket.
      You can wire the rest yourself pretty much, but I used Lark wiring. It
      is on Bob Johnstons site, or here on the forum :
      http://www.studebaker-info.org/tech/.../hondaalt.html
      http://forum.studebakerdriversclub.c...?TOPIC_ID=8919
      http://forum.studebakerdriversclub.c...?TOPIC_ID=9241
      Tom
      '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
