I am planning on a five speed trans in my 53 starliner. I will need to add a second master cylinder for the slave. Does anyone have any proven setups for either through the floor pedals or adding a swing type pedal assembly?
Master cylinder for hydraulic clutch
I copied the article in a '58 hot rod magazine that told how to put a Chevy in a "late model" Stude.
I Siamesed another brake master cylinder right next to the original one. It lined up perfectly with the clutch linkage. I removed the residual check valve in it. Used longer through bolts to attach both cylinders to the frame rail. I used an 80's Chevy truck bell housing with a built in slave cylinder. I know nothing about hydraulics, but I lucked out and the combination worked perfectly.
Dick Steinkamp
Bellingham, WA
Dick Steinkamp
Bellingham, WA
