Decoding a 1955 Stude chassi tag
  • Decoding a 1955 Stude chassi tag
    Folks, a friend o'mine is wondering about buying a 1955
    Champion, so he needs some info about its tag number...
    1bGbwb3020
    Could you decode this chassi number? Is this a real 55 Champion?
    What extra data we can get with this info[8D]?
    REGARDS
    That is not like any other serial number or body tag number I have seen on a Studebaker. Perhaps it is a unique tag for a Brazil assembled car? If you post a picture of both the serial number plate (should be on the driver's side A pillar) and the body tag (should be on the right side of the engine side of the firewall) it would help. If you can't post pictures here, send them to me at
    ddstnkmp@yahoo.com
    and I will post them for you.
    Bellingham, WA
    Bellingham, WA
      1bGbwb3020
      REGARDS
      I think that this is a misread body tag. 16G6W would be a 1955 Champion four door sedan. It is easy to think that the 6s are bs.
        As Gary guesses, that's gotta be 16G6-W6 Which is a 55 Champion 4-door in Regal trim. The 3020 is the BODY'S production sequence number.[^]
        1963 Cruiser
        1957 President two door
          Yes, the W6 identifies it as Regal four door sedan from the late 1955 production with wrap around windshield (Ultra Vista).
            Here are some pictures Francisco sent me...
            Any more help for him?
            Bellingham, WA
            Bellingham, WA
              Not sure about the tag under the head bolt. It could be the engine number. It does fit within the range of '55 Champion engine numbers.
              HEY, you're not Wilbur!
                It's a South Bend built car. The serial number tells us that. Francisco might be advised that that serial # starts out: G 1 and not G I - the old I for numeral 1 thing.[B)]
                As Dwain suggests, that could be the engine number. Maybe they also registered vehicles using the engine number and A: this makes it easier to read or B: it has a replacement block. Behond that, it could be a tag from a local shop or garage to track their work for warranty purposes. Either way, it's not a standard factory tag.
                1963 Cruiser
