Found this site about engine weights. It list 289 650 lbs. and 6 403.4. Does this seem about right.
Engine Weight
Thanks for posting that chart. It is very interesting. I only wish they had the Packard V8. They only seem to have Packard aircraft engines.
It is interesting the the 500 cu. in. Cadillac V8 is 25 lbs. lighter than the Studebaker 289.
Funny you mentioned the Caddy because more than one person suggested I'd need new front springs to handle the "heavy" Caddy on my 59 truck.
JDP
Arnold Md.
Studebaker On The Net
My Ebay Items
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP Maryland
JDP
Arnold Md.
My Ebay Items
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP Maryland
FWIW, I weighed a 1956 Studebaker 259" 2-bbl, complete with clutch, flywheel and bellhousing, ready to run, but dry. It weighed 695#. The referenced 650# weight must have been without the flywheel, clutch and bellhousing.
The 1956 Packard 352" 4-bbl dressed the same weighed 710# on the same scale on the same day.
My guess is with the supercharger and associated drive gear, the 1957 289" in the Golden Hawk weighed the same as the supposedly heavier 1956 Packard in the Golden Hawk.
The Studebaker V8 is one of the heaviest-per-cubic-inch OHV8 engines ever built. The only thing I know which comes close is the smaller Dodge and DeSoto hemi V8s.
thnx, jv.
PackardV8PackardV8
thnx, jv.
PackardV8PackardV8
Jack, The weight changes as you build them. On my 53K it weighed 3,445lbs. With an aluminum flywheel, racing clutch and pressure plate, removal of the pipe on the front of the block where the oil fills, a set of headers, and a Stu-V aluminum manifold I got the car down to 3,310lbs. The Desoto was 625lbs. and the Dodge Hemi was 495lbs. Used to use them in Cracker box boats. Put one in a Stude but the bear was the garbage trannys that you could bolt to them they were almost as heavy as the motors with that big old brake drum on the end of them.
