Needed Part
  • Needed Part
    I need a power steering control valve off of a Studebaker or lark year 1959 to 1964. If you have any information where I might look,
    I would be grateful. Please respond here or e-mail putnpar@prodigy.net Thanks!
    Identifying the part number from the chassis parts catalog would help.
    Identifying the vehicle in question would help.
    Factory Chassis Parts Catalogs are available from several Stude vendors. These same vendors probably have the part you need.
    http://www.studebakervendors.com/
      There were actually some changes to those valves in those years. You need to specify a bit more.
      1963 Cruiser
      1957 President two door
        1963 Cruiser
        Mr. B is correct. For one thing, the size of at least one of the hose fittings was changed.
        Skip Lackie
        Washington DC
        Skip Lackie
          What I need is the main body of the valve, I have all of the hardware to attach it. My mechanic says that the main valve is the same but they all have different part numbers. Thanks for responding and would appreciate any other advice. Pat
          1963 Cruiser
            What Skip said. I think it was 64 where they used larger ports on the control valve. This wouldn't be that much of a problem if you had hoses with fittings to match, but it you tried to use earlier hoses with a later valve, it would be impossible to make it work.
            IF you have a WHOLE system from a given year, it should work just fine. But just looking for a valve, you'll have to know what size hose ends there are existing. Of course, new hoses can be had, but that's more expense of course.
            1963 Cruiser
              With all due respect, I do not think your mechanic is correct. The 59-64 valve bodies are not all the same or interchangeable. You might have better luck if you specified what year the rest of the parts (especially hoses) came from.
              Skip Lackie
              Washington DC
              Skip Lackie
                Helms in Texas has new and rebult p/s units. See TW's for his ad.
                Richard
                  Thank's for the info. I am not sure what TW's is?
                  Richard
                    [quote]Originally posted by putnpar
                    [quote]
                    Turning Wheels is a monthly publication by the Studebaker Drivers Club. Go to the SDC home page for information about it.
                      TW is Turning Wheels - the official publication of the Studebaker Drivers Club. If you're not a member, you should be.
                      Bob Helm's number is 972-843-3402 After 6PM Texas time.
                      1963 Cruiser
