Looking for rear axle parts
  • Looking for rear axle parts
    The items I need are for the 44 axle housing.I need 1560657-19 spline standard axle-case assembly-TT-for 3.90-4.89 or lower gears-or just the case without the guts.
    ---or---1560446 same as above except for flanged axles with finer spline- and again the assembly or the case without the guts
    THANKS
    PAUL LAUSCH
    I have a complete 1957 3.90 TT that I'm going to ebay soon and am wondering; does the 3.90 and lower ring gear take a different carrier that the higher ratios, like 3.54?
      YES, THE ONE CARRIER IS FROM 3.07 THRU 3.73 AND THE OTHER CARRIER IS FOR 3.90 AND LOWER GEARS(I.E. HIGHER NUMERICAL GEARS)
      PAUL LAUSCH
        TT Carriers are NSS, "not sold separately" Paul.
          Yes, Studerich-I do realize that but you do run into circumstances where guys have taken some things apart and have these parts
          THANKS
          PAUL
            You might try a 4wd shop.
            Lot's of Dana44 diff's out there in Jeeps and Blazers.
            A good one should have a lot of 'outside the norm' parts.
