Why won't it crank!?!?
  • Why won't it crank!?!?
    Everything looks okay. Not sure why it won't start... Any ideas?
    Matthew Burnette
    Hazlehurst, GA
    Could be that spring to the carburetor
      Maybe the battery hold down has shorted out the battery. Many Stude owners remove theirs for that reason.
      Jim
      ____1966 Avanti II RQA 0088_______________1963 Avanti R2 63R3152____________Rabid Snail Racing
      Jim
        It's obvious, Matthew, can't you see the fuel line crimped
        right behind the oil filter? I am sure it will start right
        up with a new fuel line.
        Tex E. Grier
          Silly boy! I can clearly see that the ground cable is missing from that one water pump manifold bolt! I'm gonna hafta come to JawJuh and inpart some meccy-anickle now-lidge to you![}]
          1963 Cruiser
          1957 President two door
            LOL!
            Home of the famous Mr. Ed!
            Ron Smith
            Ron Smith
              Maybe you could pull start it.
              66 Commander R1 Clone
              51 Commander 4dr
              1962 Champ
              51 Commander 4 door
                Hook that IV pole with some gas on it
                Lenny
                Atlanta Ga.
                  Senior high prank day
                    Looks like you need a smudge pot lit underneath to warm it up real good. Then she will fire up.[:0]
                    Gordon
                      If you leave a Studebaker in the barn too long, the gas will go bad. And the rats will gnaw through the valve covers . . .
                      JohnP, driving & reviving
                      an early Lark
                      60 Lark & 58 Scotsman 4dr
                        The mouse nest in the left valve cover has jammed a push rod, which keeps the engine from turning.
                        Nothing a little Bondo and a coat of paint won't fix. I'll look for it on eBay next week.
                          Should give "Showbizkid" the incentive he needs to redo that wiring harness - piece of cake next to this "clean-up"! [:0]
                          <h5>Mark
                          '57 Transtar Deluxe
                          Vancouver Island Chapter
                          Mark Hayden
                          '66 Commander
                          Zone Coordinator
                          Pacific Can-Am Zone
                            Clark in San Diego
                            '63 F2/Lark Standard
                            www.studebakersandiego.com
                              It was my own mistake. [xx(] I forgot to turn the key on before hitting the starter button. Once I fixed that issue, she fired right up! [8D]
                              Matthew Burnette
                              Hazlehurst, GA
