Anyone use these guys for floor pans
  • Anyone use these guys for floor pans
    These guys advertise in Hemmings and ebay, but has anyone used their stuff. Price seems reasonable, $75 set.
    http://cgi.ebay.com/ebaymotors/FRONT...#ht_484wt_1182
    Actually they are $59.99 from their website:
    http://c2cfabrication.com/store/prod...roducts_id=126
    Dan White
    64 R1 GT
    64 R2 GT
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    Did you mean to include the vendor's name or website?
    Jim
    ____1966 Avanti II RQA 0088_______________1963 Avanti R2 63R3152____________Rabid Snail Racing
    Jim
      Dan White
      64 R1 GT
      64 R2 GT
      And if its the same ones I have seen on E-Bay they are priced per side,not per pair. I will tell you more in about three weeks. We are ordering a pair soon. Steve
        Been discussed many times before here. I have a set here for my 59 Lark, haven't put them in yet. They look good- pretty close but not exact same pattern as original. They'll take a little tinkering to fit, but that's true with any. 18 ga. metal. I think they're worth the money.
        Parish, central NY 13131
          Installing a set in the 54 cope right now, every thing needs to be cut to fit the area of work, but will do the trick and good price..
          Castro Valley, CA
          canbstudebakers-
          Candbstudebakers
          Castro Valley,
          California
            Those are Classic Enterprises floor pans. I used them in my 56J. There is another vendor who makes a more accurate floor pan, but I don't know the price. These will work very well unless you are looking for a show car and the judges look at the toe boards. They fit in pretty well, but as with everything you will need to do a bit of bending. The hard part is the sides by the vents. You are supplied two pieces that go from the floor pan to the sides of the kick pads. You will need to weld them in, and even with everything out of the car it is a tight fit.
              Bondo these are not CE floor pans. CE is located in WI, these are from C2C in MI. They look similar to the CE mini floor pans but are 1/3rd the price. However, the money saved may end being used in trying to force them to fit. CE is typically pretty close to the originals. If there is a better one out there I have not heard of them.
              Dan White
              64 R1 GT
              64 R2 GT
              Dan White
              64 R1 GT
              64 R2 GT
              58 C Cab
                I agree with Dan. CE's are stamped as per the originals. The pans may be important but just as important are the supports and CE's make a pretty solid installation if you buy the whole 9 yards. Good luck.
                  There is a guy down south who wsa at York and had floor pans that had the re-enfrocement treads stamped thru the curve at the bend. He also had proper C/K trunk corners, and showed a sample of his double floor for K body cars
                    Bondo or anyone else have more info on the sheet metal guy from the South?
                    Dan White
                    64 R1 GT
                    64 R2 GT
                    Dan White
                    64 R1 GT
                    64 R2 GT
                    58 C Cab
                      His name is Leroy Cary. I believe he's in Amelia, VA, west of Richmond. His business card is on my vendors page
                      Bob Johnstone
                      www.studebaker-info.org
                      64 GT Hawk
                      55 President State Sedan
                      70 Avanti (R3)
                      64 GT Hawk (K7)
                      1970 Avanti (R3)
                        Bob the picture links for Larry's stuff from you site are broken?
                        Dan White
                        64 R1 GT
                        64 R2 GT
                        Dan White
                        64 R1 GT
                        64 R2 GT
                        58 C Cab
                          email sent..
                          Bob Johnstone
                          64 GT Hawk
                          70 Avanti (R3)
                          64 GT Hawk (K7)
                          1970 Avanti (R3)
