Charging a 6 volt battery,
  • Charging a 6 volt battery,
    If i disconnect the leads , can I charge a 6 volt battery with a 10 amp 12 volt charger from sears? Dumb question caso My stude has a hot soak problem ,and the radiator cap wasn't all the way on. I will go out and try starting it in two hours.I think I might break down and buy a 6 volt battery charger, maybe this auto electrical repair place will have one.Anyone know of a commercial store that sells a 6 volt charger? I drove my stude this morning ,and the speedometer is loud as all get out, and doesn't work . I'm kind of wondering what gears are in my president , it goes slow in what I think is drive .I just called the auto electrical place ,they want $460 some odd dollars. Get out, Does walmart have one? Well I went to walmart and bought a schmacher, It looks like it could be DC also. Alot cheaper than $460. It was a hot soak problem , when I went out to go to walmart ,it turn over ,and I pulled it in the garage!
    Yeah - go get that 6V charger before you try to fry that battery! There's 6 - 12volt chargers out there that you can get that'll handle either voltage.[^]
    1963 Cruiser
    1957 President two door
      Ya need a 6-12 volt battery charger?
      Try Sears, Kmart,Walmart, Tractor Supply, Oreshelns, NAPA, Autozone, Oreillys, etc.
      3E38
      4E2
      4E28
      5E13
      7E7
      8E7
      8E12
      8E28
      59 Lark
      etc
        I bought a Schumacher battery maintainer for both 6 & 12 volt batteries at Wal-Mart some months ago. It works like a charm.
        I can use it for my Model A, which is 6v & I can use it for my '59 Lark, which is 12 volt.
        I think it only cost me about $20.
        Rog
        '59 Lark VI Regal Hardtop
        Smithtown,NY
        Smithtown,NY
          While on this subject , how does one charge one of these 8 volt batterys ?
          [IMG]
          1960 Champ
          1964 Daytona HT
            quote:Originally posted by 2R5
            While on this subject, how does one charge one of these 8 volt batterys ?
            The only way I know is to set up the Voltage regulator of a 6V car for 8 Volts, and run the engine. Never heard of an 8 Volt Charger.
              Just was wondering because there are 8 volt batterys
              [IMG]
              1960 Champ
              1964 Daytona HT
                Buick used 'em in the late 40s, early 50's. Long and very narrow. Probably had the regulator set to eight volts, as Rich suggests.
                  [IMG]
                  1960 Champ
                  1964 Daytona HT
                  They make special battery chargers for that purpose. You most likely would have to order one from a specialty supplier, though. LH
                    I have been warned to not use an 8 volt tractor battery with my 6 volt alternator. Not sure why, just know that the fellow who built the alternator knows a lot more about such things than I do.
                    Jimmie
                    Orleans, Indiana
                    [IMG]
                    1960 Champ
                    1964 Daytona HT
                    sigpicJimmie
                    Orange County, Indiana
                    1950 CHAMPION -ORANGE COUNTY, INDIANA
                      You could get 8 jolt batteries for flathead Fords to cure a hard starting problem.
                      Terry
                        Eight volt batteries have been commonly used as a "band aid" for starting problems in six volt cars, rather than diagnosing and repairing the real source of the starting problem.
                        I believe in fixing six volt cars and I do not believe in using eight volt batteries in six volt cars.
                        My chargers are combination six/12 volt. You just flip a switch. I guess that configuration isn't so common anymore.
                          Get a 6 volt tail light bulb and two 3 inch pieces of wire with both ends stripped. Solder one wire onto the brass case and another onto the lead contact button. Put that in series with either terminal of the battery and use a 12 volt charger. Trickle charges at an amp or 2.
                            Dan, That's Wonderful.
                            There must be hundreds, nay, thousands, of home remedies for things like that. I remember reading about using a piece of rind from a smoked ham to replace (temporarily) a main bearing in a Model T.
                            I wonder (new thread? how many quick and dirty (but efficient) fixes there are....
                            Tom Bredehoft
                            (Under Construction 617 hrs.)
                            '05 Legacy Ltd Wagon
                            All Indiana built cars
                              Jimmie,
                              Have the guy that built you're 6 volt alternator
                              install an 8 volt regulator. They are available.
                              If he can't find one, have him search in the fork-
                              lift section. I've been using 8 volt batteries for
                              over 3 decades now. Never a problem yet. Just
                              last year a guy says to me "I don't need an 8 volt.
                              Watch how easy my truck starts!" He proceeded to
                              crank and crank and crank. Finally he got it to
                              fire. Been there, done that too many times!
                              Use a 6 volt if you want, but I prefer an 8 volt.
                              Nice to have if you really "drive" a V-8 Studebaker
                              in the dead of winter.
