6-cylinders oil leaks
  • 6-cylinders oil leaks
    how about oil leaks on the 6's.what is there problem area? just gathering info. for future projects.
    You are who again? And you would drive a 6 Cyl. Stude.?
      a hopped up 6-cylinder might look good in a 27 t-bucket?[8D] hell i'll try anything i've even modified lawnmorrer engines (clintons) back in my day.
        The only problem that I had with a Champion six leaking oil was around the side covers when I installed the gasket wrong. The stock hub seal in the timing cover also weeps when parked, but is not a problem on the road. A modern neoprene seal would probably cure the timing cover leak.
        Bill Cathcart's site has pictures of some dressed up sixes if you haven seen them.
        1952 Champion Starlight, 1962 Daytona, both w/overdrive.Searcy,Arkansas
