body spacers
  • body spacers
    I need to know the size of the spacers that go between the frame and the body for my 51 starlight coupe project, HELP, HELP, HELP
    If you did not save, measure and mark the ones you removed, this may be a difficult task because the tire casing pieces and metal shims are custom fitted to make the body fit the frame individually on each car.
    They are a "use as required" item.
      I took a truck mud flap and cut it in squares punched a 1/2 inch hole in the middle. And a piece of 3/16 belting and done the same. The rest of the mud flap is in front of my drill press. Nothing wasted.
      http://ozarktrails.tripod.com/
      SDC Member 1985
        I bought some muffler straps to cut but I did not realize that each car was spaced to order. I was hoping that there was a specific height.
          Think of them more as shims...
          The tolerance on modern cars has vastly improved -so they serve more as a spacer/insolator nowadays.
          But the frames and bodies of old cars were hand fitted together -some went together easily and some did not. Some required more shimming here while others needed more there.
          I bagged and tagged all the shims/spacers that came off my '54 Commander. There seemed to be no rhyme or reason or particular pattern to their use.
          http://community.webshots.com/user/s...host=community
            I tagged the rubber & metal shims & numbered a corresponding sketch. My plan was to use the old steel spacers and cut new rubber ones from a mudflap (which I did). When I got to re-mounting the body; mice ate some of the tags and half of the drawing... I then went on to plan B and a lot of trial and error.
            duane miller
