Maiden voyage 63 Lark Now with video
  • Maiden voyage 63 Lark Now with video
    I finally got a few minutes to play with my Lark today. I figured the brake problem out by adjusting the pedal stop. It was not releasing all the way. The car runs and drives well. I'm tickled.
    I have a few issues. I'm going to find some Crown Vic wheels, I have a coolant leak somewhere in the dash, gotta get the tailpipes put on, the rear brakes are coming on too soon and figure out some squeaks and rattles.
    It ain't as pretty as Dick's but I like it. I even had Elvis playing in the cassette player.
    If I can figure the wifes camera out, I'll try and post some video.
    I hope this one works
    http://www.youtube.com/watch?v=LgKbTQSew1M
    A lot of wind noise in the video. It was hot.
    Jamie McLeod
    Hope Mills, NC
    Jamie McLeod
    Hope Mills, NC
    1963 Lark "Ugly Betty"
    1958 Commander "Christine"
    1964 Wagonaire "Louise"
    1955 Commander Sedan
    1964 Champ
    1960 Lark
    $20 says the coolant leak is the heater control valve, unless you've already rebuilt it. Neat idea to have a temperature-compensated valve, but I don't think they were intended to last 50 years
      Not the control valve. It's coming from higher. like the core is leaking. I can bypass it for the warm weather.
      I did get my wife to drive it around the block.[:0] We may be turning a corner here!
      Jamie McLeod
      Hope Mills, NC
      Jamie McLeod
      Hope Mills, NC
      1964 Champ
      1960 Lark
        Good going, Jamie. [8D]
        Bellingham, WA
        Bellingham, WA
          As the saying goes-
          Parish, central NY 13131
            I tried to load a video from this fancy camera, but it is not wanting to behave.
            http://www.youtube.com/watch?v=P3vztjyb6C8
            Jamie McLeod
            Hope Mills, NC
            Jamie McLeod
            Hope Mills, NC
            1964 Champ
            1960 Lark
              Worked fine for me!
              Good looking and sounding Stude.
              (somebody step on that yippy little dog )
              Bellingham, WA
              Bellingham, WA
                Cool Deal, Jamie! All these 63 Larks comin' together! I've tried to load to YouTube. Gave up eventually. But I saw yours fine.
                1963 Cruiser
                1957 President two door
                  [^][8D]
                  <h5>Mark
                  '57 Transtar Deluxe
                  Vancouver Island
                  The NW Overdrive Tour in Parksville, BC
                  May 23 & 24, 2009; check it out at -
                  http://sdcvi.shawwebspace.ca/
                  </h5>
                  Mark Hayden
                  '66 Commander
                  Zone Coordinator
                  Pacific Can-Am Zone
                    No problem with the video
                    Bonito auto !
                    Studebakerchile
                    http://www.tuerca.cl/studebakerchile/
                      Did I hear it chirp the tires shifting into second? Very cool!
                      Jeff DeWitt
                      http://carolinastudes.net
                      Jeff DeWitt
                        Yep, with the little skinny tires on it, it will chirp the tires.
                        I think I will give the the ultimate test drive today and drive it to work. A 150 mile shakedown drive should be fun.
                        Jamie McLeod
                        Hope Mills, NC
                        Jamie McLeod
                        Hope Mills, NC
                        1964 Champ
                        1960 Lark
                          .....I love shakedown rides.....no inspection sticker...questionable brakes (untried).....adventure as we all know it...take some more pics...
                            Doesn't require an inspection sticker (more than 35 years old). I drove it enough over the weekend to fully test the brakes.
                            I had to get the car on the lift today to install the tail pipes. Someone has done an excellent job underneath. All clean with stainless brake lines and an adjustable proportioning valve. I made it to work with no problems at a steady 65-70 mph. I had to disconnect the tach to get the turn signals working so I have no idea how many rpms I was turning. I got the tach hooked back up and I will find out later tonight.
                            It will be nice to get some better tires and rims on it. Overall, I'm still pleased.
                            Jamie McLeod
                            Hope Mills, NC
                            Jamie McLeod
                            Hope Mills, NC
                            1964 Champ
                            1960 Lark
                              Well, I go off for the weekend and you begin terrorizing the metropolis of Hope Mills with your Stude. Sounds great and I too liked the chirping tires in second gear. Are you going to take it to Lillington on June 6th?. It will be nice to have more than two Studes caravaning out of our region.
