64 Commander Grille Conversion
  • 64 Commander Grille Conversion
    Just curious. I just received a 64 Commander-type grille from SASCO for $25. It's beautiful!
    Has anybody converted one to a four-headlight version? It looks like it would be pretty simple - just a couple of cuts.
    Scott Rodgers
    Los Angeles
    SDC Member since 1989
    '60 Lark HT
    '63 Wagonaire
    Scott Rodgers
    Los Angeles
    \'60 Lark HT
    \'63 Wagonaire
    \'66 Frankenbaker
    I think I'm ordering a grille
    Tom - Mulberry, FL
    1964 Studebaker Daytona - 289 4V, 4-Speed (Cost To Date: $2125.60)
    Tom - Bradenton, FL
      I'm probably going to convert the one I have, I'm just working up the courage to cut a perfectly good NOS grille.
      I have a feeling if it works that there will be a run on the 2 headlight grilles left at SASCO!
      Scott Rodgers
      Los Angeles
      '60 Lark HT
      '63 Wagonaire
      Scott Rodgers
      Los Angeles
      \'60 Lark HT
      \'63 Wagonaire
      \'66 Frankenbaker
        I bought one of those last year and I cut it to fit my '64 Daytona. never would tell unless you took the headlite bezels off.
        [IMG]
        1960 Champ
        1964 Daytona HT
          2R5,
          Did you keep a piece at the top in order to make a tab for the innermost screw on the bezel? That's what I was planning...
          Scott Rodgers
          Los Angeles
          '60 Lark HT
          '63 Wagonaire
          Scott Rodgers
          Los Angeles
          \'60 Lark HT
          \'63 Wagonaire
          \'66 Frankenbaker
            Do not be afraid to cut up a NOS single headlight grill. I can personally say I saw (WITHOUT exaggeration) aprox.500 NOS single headlight grills, if not more @ SASCO Friday. If you are thinking about ordering one,or anything else,stop thinking and do it.
              Yes I did keep a tab for the screw ...make it as close as you can to your old quad headlite one. You can even cut slots in the bottom for the bezel to hook into . I cut mine with a diegrinder
              [IMG]
              1960 Champ
              1964 Daytona HT
                NO! The 2 headlamp grilles used on '64 Challengers and Commanders loook much better than the 4 headlamp units.
                <h5>Mark
                '57 Transtar Deluxe
                Vancouver Island
                The NW Overdrive Tour in Parksville, BC
                May 23 & 24, 2009; check it out at -
                http://sdcvi.shawwebspace.ca/
                </h5>
                Mark Hayden
                '66 Commander
                Zone Coordinator
                Pacific Can-Am Zone
                  Hmm.
                  Since my ugly "what if" champ project is lacking a grille I should email Sasco and join that "run" on 64 two headlight grilles
                  Say... anyone out in the midwest have any front end body parts for 64/65s with single headlights in their back yards. I've got fenders, hood and a lower valance but need grille brackets and a header panel to name a few
                  Jeff T.
                  "I'm getting nowhere as fast as I can"
                  The Replacements.
                  \"I\'m getting nowhere as fast as I can\"
                  The Replacements.
                    I did the deed over the long weekend - I cut up my Commander grille and made it a four-headlight unit. I'll post the process and pictures in the Tech Forum soon.
                    Scott Rodgers
                    Los Angeles
                    '60 Lark HT
                    '63 Wagonaire
                    Scott Rodgers
                    Los Angeles
                    \'60 Lark HT
                    \'63 Wagonaire
                    \'66 Frankenbaker
                      Hey Scott, I'll be looking for it, as over the years I've picked up 4 of these NOS single-headlamp grilles.
                      Never did anything , 'cause I didn't want to 'screw 'em up' (been waiting for someone else to.
                        I had considered converting to single lamps, but that requires either changing out the entire fenders, or drilling out buzuko spotwelds to install single H-L buckets at additional $$$, certainly not the CASO way of doing things.
                          I can now personally attest that there are PLENTY of single headlight grilles at SASCO. They were EVERYWHERE.
                          Scott Rodgers
                          Los Angeles
                          '60 Lark HT
                          '63 Wagonaire
                          Scott Rodgers
                          Los Angeles
                          \'60 Lark HT
                          \'63 Wagonaire
                          \'66 Frankenbaker
