Need to pick the brains of '37 owners....
  • Need to pick the brains of '37 owners....
    Hey guys,
    Anyone out there in Studaville ever disassembled a '37 grill for repair? Looks to be a spot weld popping job, at least! Thanks, Jimmy http://community.webshots.com/user/Jimmy655
    I'm sure that our very own Jeff Rice has...
    ___________________________________________
    Matthew Burnette
    Hazlehurst, Georgia
    '59 Scotsman PU
    '63 Daytona HT
    http://thestudillac.blogspot.com/
      Matthew Burnette
      Hazlehurst, Georgia
      '59 Scotsman PU
      '63 Daytona HT
        you have to remove the center chrome. the two halves are rivited together. drill them out. the fins are bent tabs. if the fins are not bent you can sand them from the back with a dremmel tool with a small drum sander. just tape the chrome edege. thats how I did mine. only replaced a few bottom fins. hope this helps. good luck
        frank
          frank
            What Frank said....
            If you can find a source for replacements for that center stainless strip, let me know.
            I pray for your sanity for what you are about to partake..
            [quote]Originally posted by mbstude
            DEEPNHOCK at Gmail.com
            Brooklet, Georgia
            '61 Hawk (project)
              What Frank said....
              Brooklet, Georgia
              '61 Hawk (project)
                Thanks Frank....Kinda scary, the thought of poppin' that grill center spine open but the spine itself isn't straight and there's no other way to do it. What's the story on the solid round bar inside the center spine? support, keeping the inside louver tabs in place?
                Hey Jeff...too late, I've already lost my sanity during the inital stages of the IFS install (see latest photo). Fatman's (a company I've always had high reguard for) '37 Studebaker crossmember leaves much to be desired! Finally just said the heck with it and decided to mark the frame for a level crossmember @ 3 degree forward rake and when the frame doesn't cooperate, I'll fabricate. Thanks guys...Jimmy http://community.webshots.com/user/Jimmy655
                    Having installed a couple of FatMan Fab front ends (into non-Stude's), I can tell you that all the older stuff is 'close', but rarely is it precise. But, rarely do 65+ year old frames stay square, either. Just square up your frame (check the diagonals too!) and block it for setting the new crossmember. Make sure you set the crossmember so you can get the right caster, or you may make it harder to align, Also think hard about your finished ride height and your lower grille section. Since you are rebuilding your grille, you should consider recountouring the lower nose grille opening to flatten it out a bit. Otherwise, if you set your ride height 'in the weeds', you will live in fear of every curb and gas station driveway when you drive[B)].
                    You really won't see the bottom of the nose enough to say it doesn't look right, but an additional inch of ground clearance there can help you soften the front suspension so it rides nice without fear of scraping the nose. (BTDT)...
                    Brooklet, Georgia
                    '61 Hawk (project)
                      Brooklet, Georgia
                      '61 Hawk (project)
                        Jeff,
                        Posted my reply on the tech forum.....Jimmy
                          Jeff,
                            I heard that the rear side strip from a 65 buick special 2 door can be used for the center strip. I had a good one off the parts car so did not have to try it.
                            Frank
                              Frank
