Transtar ID
  • Transtar ID
    I got the body tag off the Transtar cab that the dash pad came from that I put on the '59. I was told that the cab is a '57. The serial # is E16-45365 and the model # is 4E16-155. The HP rating is 95 HP at 3200 RPM and the gross weight is 15,000 lbs. So, what can you ID masterminds tell me about this one?
    ___________________________________________
    Matthew Burnette
    Hazlehurst, Georgia
    '59 Scotsman PU
    '63 Daytona HT
    http://thestudillac.blogspot.com/
    I'm no mastermind but from what you said and what Mike has just posted. Its the heavest Studebaker 1 ton on the planet. weighing in at a lofty 15,000 pounds.[B)]
    www.AutomotiveHistoryOnline.com
        This is a 1959 1 1/2 ton truck with the Big 6 (245 CID Commander) motor in it. It was available with a 131", 155" or 171" wheelbase. The beginning 4E16 serial number for 1959 was 45301, so it is near the beginning of production. If Matt can post the entire sequence from the bottom of the tag I can provide the front and rear axle ratings, the rear axle ratio and the brake equipment. It should read something like this:
        4E16--155--5 F1 C S
          4E16--155--5 F1 C S
            So it's a '59 eh? Good to know.
            Actually it doesn't have anything after the 155. [8]
            Here's a scan of the tag.
            Matthew Burnette
            Hazlehurst, Georgia
            '59 Scotsman PU
            '63 Daytona HT
              Matthew Burnette
              Hazlehurst, Georgia
              '59 Scotsman PU
              '63 Daytona HT
                Just so you know, E = 1955, 2E = 1956, 3E = 1957 & 1958, 4E = 1959, 5E = 1960, 6E = 1961, 7E = 1962 and 8E = 1963 and 1964.
                That would tell me that it is just a plain old 1 1/2 ton 6 cylinder truck!
                    Guido from the information I found in the 57-61 truck parts book,
                    the added information on the bottom of the tag started with the 5E series of trucks(that would be 1960 mbstude)
                    3E38
                    4E2
                    4E28
                    5E13
                    7E7
                    8E7
                    8E12
                    8E28
                    4E2
                    59 Lark
                    etc
                      3E38
                      4E2
                      4E28
                      5E13
                      7E7
                      8E7
                      8E12
                      8E28
                      4E2
                      59 Lark
                      etc
                        Well, from what's left of the truck (a cab with doors) it did have a few options. Doors locks in both doors, door visors, and the check mark trim as well. I think it had the 'Deluxe' script on it too.
                        Matthew Burnette
                        Hazlehurst, Georgia
                        '59 Scotsman PU
                        '63 Daytona HT
                          Matthew Burnette
                          Hazlehurst, Georgia
                          '59 Scotsman PU
                          '63 Daytona HT
                            Matthew - You now also know that the tag is technically not off a "Transtar", but rather off a 1959 Deluxe truck.
                            1959 DeLuxe pickup (restomod)
