'58 Sedan Delivery
  • '58 Sedan Delivery
    Frank Drumheller (StudeLark) sent me the following info and pictures as a follow up to our discussion on Sedan Deliverys
    Thanks, Frank!
    Dick; Thanks for offering to post pix of the '58 Scotsman Panel-wagon (sedan delivery by other manufacturers) on the thread. I have three (3) different pieces of factory literature which shows the Panel-wagon.
    # 1 & 2 photos- front and rear covers
    A single fold, 4 page folder for the factory Panel-wagon. Printing code PD 8068. This folder covers a factory assembled Panel-wagon. There are three (3) additional standard components added to a stock 2 door station wagon to create a Panel-wagon. These components were a rear dome light, a rear deck lip bridge and a pair of removable side panels. There were no changes in the model code or serial number to designate a Panel-wagon.
    # 3 photo
    A one page sheet from the sales accessories' manual for the NEW PANEL WAGON CHANGEOVER KIT. This kit was sold as an accessory so a 2 door wagon, 1958 and prior models, could be converted to a Panel Wagon (note the different nomenclature). This kit differed from the factory built Panel-wagon as the rear dome light was not included in the kit. This sheet is dated April 24, 1958, there is no printing code. Suggested dealer net price- $22.75, suggested list price- $32.50.
    # 4 photo
    On the back of the 1958 Scotsman pickup 2 page flyer is a small picture of a 1958 Panel-wagon in the bottom right corner. Printing code PD-8076.
    I learned- if it was a factory built vehicle, it was called the Panel-wagon.
    I learned- if it was owner or dealer accessorized, it was called the Panel Wagon.
    Bellingham, WA
    Bellingham, WA
    At the risk of sounding stupid...a speciality of mine...
    How did they attach the side panels?
    An earlier post said they were they made of Masonite...more to the point what's Masonite?
    63 Avanti R1 2788
    1914 Stutz Bearcat
    (George Barris replica)
    Washington State
    63 Avanti R1 2788
    1914 Stutz Bearcat
    Washington State
      63 Avanti R1 2788
      1914 Stutz Bearcat
      Washington State
      63 Avanti R1 2788
      1914 Stutz Bearcat
      Washington State
        Here's a blow up of one of the pages Frank sent. It helps explain how they were attached, but still somewhat unclear...
        "Masonite is a type of hardboard formed using the Mason method (invented by William H. Mason) by taking wooden chips and blasting them into long fibres using steam and then forming it into boards. The boards are then pressed and heated to form the finished boards. No glue or other material is added. The long fibres give Masonite a high bending strength, tensile strength and stability."
        http://en.wikipedia.org/wiki/Masonite
        Bellingham, WA
        Bellingham, WA
          Bellingham, WA
          Bellingham, WA
            Masonite is pretty durable stuff. My uncle used a lot of it on his house not long ago for stucco.
            ___________________________________________
            Matthew Burnette
            Hazlehurst, Georgia
            '59 Scotsman PU
            '63 Daytona HT
            http://thestudillac.blogspot.com/
              Matthew Burnette
              Hazlehurst, Georgia
              '59 Scotsman PU
              '63 Daytona HT
                _____________________________________________________________________
                That's a good question. I've never actually seen how they are attached on a live vehicle. Somewhere, and I can't find the source, I read something about 'screws' to attach the panels. Question- to screw into what?. Hopefully, someone out in Studeland will have an answer.
                BTW, the items in the 1958 factory literature also applies to the 1959 Panel-Wagons.
                Frank Drumheller
                Louisa, VA
                '60 Lark Regal VI 4 door
                '48 M16-52 Studebaker/Boyer Fire Truck
                16-18 'junquers' on the hill
                  Frank Drumheller
                  Louisa, VA
                    It said on the other thread they were attached using clips.
                    David Baggett Mantachie,Ms.
                        It sure looks like those panels are clipped to the outside of the rear windows, but any Masonite I've ever seen was pretty moisture-sensitive. It'll either warp or outright turn to mush when exposed to the weather.
                        Any Masonite I've seen has one very hard, smooth, almost glazed surface, and a surface that looks like it was impressed by window screen.
                            If someone wanted to make one of these, I would think you could use the paneling often installed in bathrooms (it's pretty much masonite with a plastocene surface) and the snaps that were used in convertibles for the boot covers and are still used for truck bed covers.
                            Brad Johnson
                            33 Rockne 10
                            51 Commander Starlight
                            53 Commander Starlight
                              Brad Johnson
                              33 Rockne 10
