3 Speed OD Shifter Mount Plates Found!
  • 3 Speed OD Shifter Mount Plates Found!
    I finally found a set of shifter mount plates for the T-96 3 speed OD tranny in my 63 Wagonaire!:
    It was on Ebay, listed for a 49-51 Ford OD 3 speed tranny. I have a Ford transmission book from the 50's - there was a T-96 listed for the years covered. I took the chance and bought the setup for $60. It fits perfectly, including the linkages. It was made for a Mystery Shifter, but the Hurst Indy setup I had worked just fine. The only modification I have to make to mount the brackets is to drill and tap a small hole in the tranny case to mount the side bracket - it's for the hole on the lower tab of the silver plate in the photo. I assume this had to be done for the tranny in Fords too.
    Here's a picture of the brackets assembled. The top hole is for the shifter pivot:
    Here's the completed shifter in the car:
    If you're looking for a floor shift for a 3 speed OD (at least a T-96), keep these pictures for your search. Unfortunately, I don't have a manufacturer or part number for the set.
    If anyone knows of a shop that has one of those fancy automated plasma
    cutters, I'd be willing to lend the pieces to anyone who wants to get the mounting plates copied - I'd like to get an extra set myself. If anyone has any ideas, let me know.
    Scott Rodgers
    Los Angeles
    SDC Member since 1989
    '60 Lark HT
    '63 Wagonaire
    Scott Rodgers
    Los Angeles
    \'60 Lark HT
    \'63 Wagonaire
    \'66 Frankenbaker
    Here's a bigger picture of the mounting plates:
    Here's the top plate mounted on the tranny in my 63' Wagonaire:
    Scott Rodgers
    Los Angeles
    '60 Lark HT
    '63 Wagonaire
    Scott Rodgers
    Los Angeles
    \'60 Lark HT
    \'63 Wagonaire
    \'66 Frankenbaker
      Excellent Scott! I know I sure like having a floor shift (T-86) much more than a column shift on my Transtar. [^]
      <h5>Mark
      '57 Transtar Deluxe
      Vancouver Island
      The NW Overdrive Tour in Parksville, BC
      May 23 & 24, 2009; check it out at -
      http://sdcvi.shawwebspace.ca/
      </h5>
      Mark Hayden
      '66 Commander
      Zone Coordinator
      Pacific Can-Am Zone
        Mark,
        I do like a floor shifter better, especially with a 3 speed. Now I can mount my Ididit column with tilt!
        Scott Rodgers
        Los Angeles
        '60 Lark HT
        '63 Wagonaire
        Scott Rodgers
        Los Angeles
        \'60 Lark HT
        \'63 Wagonaire
        \'66 Frankenbaker
          T-96??? or T-86???
          You runnin' a OHV 6 in that Wagonaire???
          1963 Cruiser
          1957 President two door
            T-96 and yes, I do have an OHV 6.
            Scott Rodgers
            Los Angeles
            '60 Lark HT
            '63 Wagonaire
            Scott Rodgers
            Los Angeles
            \'60 Lark HT
            \'63 Wagonaire
            \'66 Frankenbaker
