The custom Champ is coming along
  • The custom Champ is coming along
    Getting some work done in the last few days, yesterday I got the broken screws out of the lower door hinge mount. Earlier that day, I picked up a bag of cone head screws and conical lock washers to replace the stock screws in this truck projext and my hardtop.
    I hung the right door so it closes with a good slam. I will need to bring down the floor jack to hold it while I tweek it some so it will close with a push.
    Things to do in the next few days, budget and time permitting:
    Need to go to a local metal supplier for some square tube to run from the hinge post to lock post and points back and get some plate to make some new body mount brackets.
    Need to get a degreaser to remove what I think is tranny lube off some of the floor before I try to weld... how tranny lube got there????
    Need to figure out where I can get used conveyer belt for body mounts locally.
    Need to drill out broken screws in the left door.
    Need to figure out floor welding joint style, lap joints, butt joints, plug welding, not worried about looks... once I build it, I'll beat it and fix it
    Anybody ever use a piece of angle iron, some vise-grips and a hammer as a metal brake?
    Going to see what I can do on the truck in the next day or two, I also need to start on a fence around the yard to keep in an active three year old and the future puppy she desires.
    Jeff T.
    "I'm getting nowhere as fast as I can"
    The Replacements.
    \"I\'m getting nowhere as fast as I can\"
    The Replacements.
    We want pictures! You say it's a custom Champ, what are you planning on doing to it?
    Jeff DeWitt
    http://carolinastudes.net
    Jeff DeWitt
      You can just as easily cut pieces out of tire sidewalls- they look and work as good as originals.
      quote:Anybody ever use a piece of angle iron, some vise-grips and a hammer as a metal brake?
      Sure enough. That's all I've ever had. I used Vise Grips as you said, but also clamped the works in my big bench vise. If you carefully start your bend by hand as close to the angle iron as possible, then gradually hammer it over with a big hammer and wood block, you can do almost as good as a brake. If you don't use the wood you'll get hammer marks, bit you can make a really sharp bend that way. If you need a bend beyond 90 degrees, work the bend over the verticles instead of the flats of the angle iron. Just takes a little practice.
      Parish, central NY 13131
        How about something like this?
          quote:Originally posted by LC7
          Now there's an interesting truck. [8D]
          <h5>Mark
          '57 Transtar Deluxe
          Vancouver Island
          The NW Overdrive Tour in Parksville, BC
          May 23 & 24, 2009; check it out at -
          http://sdcvi.shawwebspace.ca/
          </h5>
          Mark Hayden
          '66 Commander
          Zone Coordinator
          Pacific Can-Am Zone
            Yea, that is what I am up to, except I am using a 63 Wagoneer body (flat roof, squarer rear door). Work is slow because I can only work on it one or two hours a week. I wish I had held onto the scrap truck frame rails I once had for donor material to lengthen the frame, otherwise I have to section down the cab to an extended from rough crew size to fit a 122" wb frame with a six foot box.
            I'll get some pictures after I peruse the flickr or similar sites and review creative commoms licences, just in case.
            Jeff T,
            The Replacements.
            The Replacements.
              Hey, that's cool...That's the idea (more or less) that crossed my mind while I was looking at that '59 Lark wagon hulk near here a couple months back...a wagon body on a truck chassis. In the case of a 59, the result would have been Blazeresque, a sort of "Champ Conestoga". Looking forward to seeing pix of this 63 project.
              S.
                HEY Jeff!
                I'll bet it's missing a transmission!! LOL
                Jim
                their Memorials!
                  Jeff, you can use the angle iron as a metal brake with the vise grips but use a body "dinging spoon" instead of just hitting the angle with a hammer. The spoon will roll the metal easier woth alot less distorion. Do it in a vise is even better with the metal between 2 lengths of angle iron & you have a open area to work, nice & stable too! If you dont have a dinging spoon, then a block of hardwood would do, but the spoon is better.
                  60 Lark convertible
                  61 Champ
                  62 Daytona convertible
                  63 G.T. R-2,4 speed
                  63 Avanti (2)
                  66 Daytona Sport Sedan
                  60 Lark convertible V-8 auto
                  61 Champ 1/2 ton 4 speed
                  62 Champ 3/4 ton auto
                  63 G.T. Hawk R-2,4 speed
                  63 Avanti (2) R-1 auto
                  64 Zip Van
                  66 Cruiser V-8 auto
                    60 Lark convertible
                    61 Champ
                    63 G.T. R-2,4 speed
                    63 Avanti (2)
                    Another option is a leather-faced mallet. A 3 lb mallet works well for stuff like this, even up to 1/8".
                    Paul
                    Winston-Salem, NC
                    Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
                    Paul
                    Winston-Salem, NC
