How to know if a Stude (or X) has Rust issues
  • How to know if a Stude (or X) has Rust issues
    I thought this thread could be insightful for persons unfamiliar with rust. (and could be fun). I'll start.
    How to tell if your car has Rust Issues.
    (1) When you step on the gas, there is a good chance you could end up in the back seat.
    (2) The sheet metal man knows you by first name, and you have to use a credit card because the purchase price always exceeds the cash in your pocket.
    (3) The metal sensor on some roads to change the traffic lights doesn't detect your car is there.
    Paul
    You have your car body sandblasted, and wind up with just a frame.
    You make a new hole every time you try to patch up an existing one.
    Your car leaves a little pile every time it hits a pothole.
      You can put your suitcases on top of the gas tank.
      A conservation group wants your car for an underwater reef.
      Ziebart closes when they see you coming.
      Lark Parker --Just an innocent possum strolling down life's highway.
        • You do not need to roll down your window for ventilation
        • You need to wear safety goggles to keep debris from the floor out of your eyes
        • Your kids never ask you to stop anymore for bathroom breaks
          A couple from my past:
          1. When you step on the brakes at a stop sign and the front end dips down and comes back; then a few stops later you take off and the cowl breaks loose and drops and the brake pedal traps your big toe between itself and the floor, crushing it (66 Falcon)
          2. You have to smoke the tires with that 327 4-speed every time you take off; then one time you do so, and when you grab second and sidestep the clutch, the rear axle and what's left of the last several feet of the frame try to exit out the rear- with a big bang and a momentary skyward leap of the rear of the car (63 Impala SS)
          3. More recently: When you pull the rug out and see there's no connection between the floor and A-pillar- all the way to the windshield! You open the pass. door and it falls to the ground- A-pillar still attatched (62 Daytona Skytop)
          Being a CNY resident my whole life, I could come up with hundreds[B)]
          Parish, central NY 13131
            You can stand in the driveway on quiet nights and hear the flakes hitting the ground.
            Clark in San Diego
            '63 F2/Lark Standard
            www.studebakersandiego.com
              Most recent surprise along these lines came when driving a fairly good-looking but heavily bondoed 1965 Cadillac convertible maybe four years ago. These cars can have notoriously rusty frames that are downright dangerous.
              In this case, unbeknownst to me, the lower left control arm front mount to the frame (normal coil-spring rear suspension) had rusted off its mount...or should I say the area of the frame to which the mount had been attached had rusted away. The lower right control arm was more-or-less locating the bottom of the rear axle housing, at least for the time being. (Needless to say, the car did drive squirrely.)
              But when you applied the brakes anything but gently, the axle housing could rotate just enough, taking that errant control arm with it. In so doing, that control arm contacted the emergency brake cable running below it, immediately and violently applying the emergency brake, locking up the rear brakes even though you were attempting a smooth, normal, non-panic stop! Talk about frightening the first time it happened... BP
              Ayn Rand:
                When you have more squished bugs on your knees and ankles than on your windshield!
                If your car was made before 1995!
                I have only two limitations ...BRAINS & ENERGY
                  When it's reallllyyy bad;
                  Your repair knowledge of cables and trusswork talents on the frame would make any engineer from the Golden Gate Bridge tear up.
                  [img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000137-1.jpg[/img=left][img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000145-1.jpg[/img=left][IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
                  [IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
                    Paul
                    I think Mark's post on this thread, 6th from the end is the ultimate rust test!![}]
                    http://forum.studebakerdriversclub.c...Terms=rustiest,
                      Err, Just kinda curious how may times it happened that were not frightening. [)]
                      Bob
                        Your kid wants to take the car to school....for chemistry class show & tell.
                        You decide it's cheaper to paint your driveway ochre.
                        Pennsylvania's motor vehicle code is often appropriately denigrated but, when properly done, the annual motor vehicle inspection has its attributes. I can hear my S-10 rusting but it's still safe to drive.
                          How about this one:
                          When your 67-72 Ford pick-up cab mounts get so bad that the steering starts binding; then all steering is eventually lost, because for some time the entire weight of the cab was being supported by the steering column, and the rag joint finally gave up the ghost[:0]
                          Saw it plenty of times back in the day...
                            I like the one from a while back on this forum about the Jeep Wagoneer Back Seat VCR Catapult...look it up...
                            S.
                              S.
                              Scroll UP five posts!! Save yourself the search!
