Serial number plate (Door jamb) for '55 Commander
  • Serial number plate (Door jamb) for '55 Commander
    Can someone provide me with a picture of the proper serial number plate for a '55 Commander? A friend is missing theirs and needs to know what the correct size, shape, etc. is. We don't need the numbers, just the correct format. Thanks
    Howard
    '62 GT Hawk (4 speed, A/C, Power steering - running and DRIVING!)
    Here is a '55 President Coupe, it looks like the same Black Block Style, but by '56 they must have added Packard to it, they were already TWO Years Late doing that in '55.
    I can't help with the size but it will fit between the Dimples for the Welds and the 2 locating screw holes on the Door Post.
    Click image for larger version  Name:	President Coupe2.jpg Views:	0 Size:	75.6 KB ID:	1945441 Click image for larger version  Name:	58SHCoppertone8.jpg Views:	0 Size:	100.1 KB ID:	1945442
    For others that may be interested, the '56 to '62 would look like this Pic # 2 of 1958 Silver Hawk.
    As you can clearly see from these very typical examples, Engineering had it all figured out, & idiot proofed, just line up the Notches with the screw holes, install 2 Screws and Weld all 4 Corners to keep it secure.
    HOWEVER, with the infinite wisdom of UAW Local 5 line workers, they just masking taped it on any old way, hit it often times twice, diagonally with the Arc Welder, and saved 2 Screws and maybe a Minute or two.
    Engineering even gave them 4 Dimples to put the Welds into! Did it happen... Never.
      Thanks Rich
